Go Back   Automotive Forums .com Car Chat > Chrysler > Lebaron
Old 08-09-2022, 08:19 PM   #1
corvairbob
95 lebaron question
i have the 95 lebaron lx and i just started having an issue that i have not yet fried to figure out, so before i start messing with this maybe someone here may have had this and can save me some time.
what i got is a couple of times when i try to start it i get nothing the seats work the headlights do not dime the battery seems fine then if i try a few time's it finally starts. so i can wait until the next time i need to go somewhere and it fails and i spend a few hours tracking this down or maybe some here have had this issue and can point me to it to save a bit of time. it can be the ign. maybe the brake switch the neutral switch or a relay in the start circuit. i guess i can change them all out and get it that way. i guess it could be the starter relay if the starter has one or even the brushes on the starter. but it has not yet failed completely so this make it a bit tougher to find. if someone happens to have the wiring diagram for this car that would be good as i can start tracing it down. like i said is it failed completely it would be easy enough. also i pulled the codes and i have none a steady 55 not even the 10 or is it 12 for the start of codes but i do not thin this car ever gave me 10 or 12 for a start only 55 for end
anyway this has now happened 2 times and only after it has sat for a week or so then it start just fine after that first failure.
so if no one has had this or it is not a common issue then a wire diagram for the start circuit will help for the 95 lebaron. thanks
corvairbob is offline   Reply With Quote
Old 09-05-2022, 08:18 AM   #2
corvairbob
Re: 95 lebaron question
ok seems no one has a clue so i will figure this out myself thanks anyway. i think the starter relay is failing. and the next time it does this i will swap out relays with another one and see if i get the issue again then it will be the ign switch but the relay is the easiest to start with. thanks
Old 09-05-2022, 12:29 PM   #3
Stealthee
Your worst nightmare
Stealthee's Avatar
If it does it again bump the shifter to see if it is all the way in park, or pull it into neutral.
Stealthee is offline   Reply With Quote
Old 09-05-2022, 12:54 PM   #4
corvairbob
thanks done that before and no difference and i tried the brake thinking it had a brake switch also but mine does not thanks
