| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
08-12-2007, 02:05 PM | #1 | |
Why does my front end bounce?
I know I could be burned alive at the stake for asking this question here, but the Dodge forum is kinda slow and I need an expert answer, as soon as possible.
My truck's front end bounces at speed. It starts when I'm going over 60mph on the highway and hit a bump in the road, then the thing bounces up and down, almost uncontrollably. It only stops when I slow down. I was told it was the steering damper, the shock in the middle, but replacing that didn't help the problem at all. What could be causing this?
1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
08-12-2007, 02:24 PM | #2 | |
Re: Why does my front end bounce?
my chevy did that, get some gas matics and it will help fix the problem, but the main cause for that is the springs arent as good as they used to be when you hit a bump it compresses them a bit and springs you up and down. aka the front suspension could be going bad
08-12-2007, 02:50 PM | #3 | |
AF -Advisor
bouncing up and down, with no roll, is always shocks/struts
compression and damping is what limits/regulates bouncing, and thats completely regulated by the shocks/struts on any vehicle.
life begins at 10psi of boost Three turbo'd motorcycles and counting. |
08-12-2007, 07:12 PM | #4 | |
As Bob said, it's the shocks.
First check the mounting bushes. If they're shot then it might be a cheap fix. If the mounts are fine then it's the shocks that're shot. |
08-14-2007, 12:57 PM | #5 | |
shocks could have just come un mounted too.
08-14-2007, 01:48 PM | #6 | |
Kind of a Big Deal
you have a dodge right? i thought those had torsion bars....maybe those are crapped out?
08-14-2007, 02:41 PM | #7 | |
hey dyno what year & miles on it
08-14-2007, 05:55 PM | #8 | ||
08-14-2007, 06:29 PM | #9 | |
if the shocks are in order check the ball joints for wear
08-14-2007, 07:38 PM | #10 | ||
If the springs were shot, the front end would be hanging low. |
08-14-2007, 09:28 PM | #11 | |
Kind of a Big Deal
thats true.. oh well i thought id throw something out there.
08-15-2007, 02:38 PM | #12 | |
check your alignment that will tell you if somethings out of wack if springs are weak that will also show up
