Go Back   Automotive Forums .com Car Chat > Dodge > Intrepid
Old 11-04-2004, 01:03 PM   #16
theFREAKnasty82
theFREAKnasty82's Avatar
Re: 1998 Dodge Intrepid smokes...
since you have a 98, here's what you can do, depending on how much you are willing to spend: since you have to take off the camshafts just to replace the valve guide seals, go on and replace your timing chain and tensioner as well as water pump, it's right there inside the timing cover. Next, if your fianances allow, you can take off your oil pan and either clean up or replace your pick-up screen making sure it's not gummed up. Other than that, with those items replaced, you are guaranteed to have 100+ miles of reliable service as long as you regularly use synthetic oil.
theFREAKnasty82 is offline   Reply With Quote
Old 11-04-2004, 05:28 PM   #17
shaneland
thanks that helps allot...
what did you mean by 100+ miles? You mean 1,000 10,000 miles???
Is there a fix for the oil pickup tube??
Heres an auction I found...he lists a solution to the flaw...does anyone know the exact flaw and how to fix it??
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
I hope maybe one day I can return the favor of helping you guys out...
shaneland is offline   Reply With Quote
Old 11-04-2004, 11:52 PM   #18
theFREAKnasty82
sorry, I meant 100,000+ miles, my mistake
Old 11-05-2004, 12:04 AM   #19
theFREAKnasty82
I'm not 100% sure about the flaw that he is referring to, I e-mailed those people to see if there's something that I'm missing. Oh yes, one other thing that you can do since you'll have everything apart, you can replace your cam & crank seals, to prevent any oil leakage. If you do all those things, I believe it is safe to say that you will have a reliable engine.
Old 11-05-2004, 04:03 PM   #20
shaneland
today I flushed the engine with motor flush. My clean oil came out BLACK. Good sign but also a bad sign. I added havoline synthetic for now. Gonna use the cheap oil for 500 miles and then do another flush and add mobil 1.
Engine overall is quiet and no leaks.
Odd thing is I didnt notice and smoke this time I drove around the block...any ideas???
Old 11-06-2004, 01:12 PM   #21
theFREAKnasty82
A very important word of caution, you CANNOT mix regular motor oil and synthetic, they don't mix. It's literally like adding water & oil together. So be very careful about that b/c you could sludge things up very quickly. About the smoke not happening, some motor oils recondition old seals in engines. Chances are you used a brand of oil that reconditioned them and now they work just fine; weird I know, but cars have a mind of their own; they baffle me all the time and I work on them for a living!
Old 11-06-2004, 03:37 PM   #22
LMP
LMP's Avatar
lol ...they sell oil that is part synthetic, part regular.
LMP is offline   Reply With Quote
Old 11-02-2012, 07:40 AM   #23
bfoss31
Send a message via Yahoo to bfoss31
Hello,
I found this post when googling the same issue with my 1998 Dodge Intrepid. It's a Great Running Car with just over 100k on it, gas mileage is Awesome!
I know that this thread is from 2004. So I am just curious if I can get a reasonable guess on how much it would cost me to have a mechanic replace the valve guide seals as mentioned.
Thank You
Brian
bfoss31 is offline   Reply With Quote
Old 02-14-2013, 02:15 PM   #24
dreager
You said you needed a service manual, go here:
http://manuals.dodgeintrepidchat.net...anuals/Service Manuals/
1999 Buick Century Custom 3.1L , 148,000km. 2000 Toyota Echo, 1.5L 220,000km
dreager is offline   Reply With Quote
Bookmarks
Search this Thread:
