Go Back   Automotive Forums .com Car Chat > Maserati > Biturbo
Old 07-19-2005, 05:06 PM   #1
Julian Formosa
Parts for sale
Hi guys, I have all these new Maserati parts for sale, check the part numbers and contact me for a price. Let's keep these beauties on the road.
Regards
Julian
PART NO DESC QTY
T124900060 NUT 3
T125400140 NUT 1
T177908000 BALL 1
T192415208 RUBBER 1
T30331130 ELECT WINDOW SWITCH 2
T30811327 CAP 1
T310220033 STEERING KIT 1
T310220034 STG BOX KIT 1
T310220035 REAR BRAKE PADS SET 2
T310220039 BRAKE PAD KIT 3
T310232033 CLAMP KIT 1
T310232034 JOINT KIT 2
T310254039 PAD BRAKE SET FRT MAS 2
T310254042 SHOE BRAKE MASERATI 2
T310420302 ENGINE SUMP 1
T310420304 PLUG OIL DRAIN 5
T310420305 SUMP GASKET 3
T310422008 ENGINE BLOCK GASKET SET 3
T310425019 ENG BLOCK ASSY 1
T310620003 CYL HEAD 2
T310620302 VALVE INLET 6
T310620352 SHIM 2
T310620353 OIL RETAINER 2
T310620359 GASKET 6
T310620360 CONNECTOR 2
T310620418 CYL HD GSKT 4
T310620460 OUTLET WATER 1
T310625320 CYLINDER HEAD GASKET 2
T311020005 CHAIN TENSIONER 1
T311020321 GASKET 3
T311020353 PIN 1
T311020355 SUPPORT 1
T311020358 SPRING 1
T311025329 OIL TRAPPER 1
T311320300 FRT PANEL INSIDE 222E 1
T311322103 FRT PANEL ASSY 222E 2
T311351228 REAR PANEL SPIDER 2.8 1
T311420104 SEAL RING 2
T311820100 OIL FILTER 12
T312020008 COLLECTOR 1
T312020013 TURBO CHARGER L/H 1
T312020014 TURBO CHARGER R/H 1
T312020307 GASKET 4
T312020309 NUT 12
T312020310 GASKET 2
T312020318 SLEEVE SPIDER 2
T312020329 GASKET 14
T312020358 COVER MASERATI 1
T312020405 OIL OUTLET 2
T312020408 OIL OUTLET 2
T312020411 GASKET MASERATI 2
T312020422 HOSE 4
T312020424 HOSE MASERATI 1
T312220408 SEAL 1
T312220422 GASKET 2
T312320376 KEY LUGGAGE BOOTH SPIDER 1
T312420100 STRAP AIR CLEANER 6
T312420104 BEARING 4
T312420306 HOSE 2
T312420310 HOSE TURBO MASERATI 425 1
T312420319 HOSE TURBO 222E 1
T312420330 HOSE TURBO 222E 1
T312430303 FILTER ELEMENT 1
T312450336 HOSE TURBO 222E 1
T312520504 SCREW PLUG U/BONNET 10
T312520505 MUD SHIELD L/H 222E 1
T312520506 MUD SHIELD R/H 222E 1
T312520507 RUBBER STRIP 222E 1
T312520508 RUBBER STRIP 222E 1
T312520509 SCREW PLUG U/BONNET 10
T312550301 WING PANEL L/H 222E 2
T312550302 WING PANEL R/H 222E 2
T313020104 FUSIBLE 1
T313020208 REGULATOR 2
T313020209 RECTIFIER 1
T313020421 BELT 2
T313050422 SPACER 2
T313120103 LAMP ASSY MASERATI 1
T313120104 LAMP ASSY 2
T313120127 SIDE LAMP 2
T313120130 LAMP ASSY FRT R/H 2 2
T313120137 RIGHT HAND REAR LAMP 1
T313120138 LEFT HAND REAR LAMP 1
T313120201 INSIDE LAMP 1
T313120402 R.H. LENS (BITURBO 2000) 2
T313121109 FOG LIGHT ASSEMBLY (BITURBO 20 1
T313127102 HEADLAMP INSIDE 222E 5
T313151152 LAMP ASSY R/H REAR 1
T313220100 ELECTRONIC BOX 1
T313220101 IGNITION COIL 1
T313220110 IGNITION COIL 1
T313220111 IGNITION COIL 1
T313220112 ACCEL SENSOR MASER 1
T313220202 DISTRIBUTOR COVER 1
T313220203 ROTOR ARM 3
T313220214 IMPULSOR 1
T313220221 DIST CAP 222E 2
T313220222 ROTOR ARM 1
T313250220 CABLE HIGH TENSION 2
T313320118 WIPER ARM 2
T313320119 WIPER BLADE 2
T313320125 FOG LIGHT SWITCH (BITURBO 2000 3
T313320126 REAR FOG LIGHT SWITCH (2000 BI 3
T313320134 RELAY 2
T313320161 RELAY 1
T313320162 MABC GEARCASE 1
T313320163 SOLENOID VALVE 2
T313320164 SENSOR 1
T313320165 ACCELERATOR SENSOR 2
T313320172 SWITCH THERMO 1
T313320181 MABC GEARCASE 1
T313327118 COVER W/ARM MASERATI 2
T313330176 PUMP MASERATI 2500CC 1
T313420102 IGNITION KEY 2
T313420203 SOLENOID SW 1
T313420205 ARMATURE 1
T313420206 FIELD COILS 1
T313420212 FIELD COIL 1
T313420213 COUPLING 1
T313420214 ARMATURE 1
T313420215 BRUSH KIT 1
T313420216 BRUSH HOLDER 1
T313420218 SOLENOID VALVE 1
T313420407 BUSH 1
T313420410 BUSH 1
T313420415 BUSH 1
T313420420 BUSH 1
T313630102 TEMP SENDING UNIT 3
T313650105 OIL PRESSURE SWITCH 222 4
T313720116 TEMPERATURE AIR MASER 1
T313720117 SENSOR MASE 1
T313720121 INJECTOR MASER 2
T313737125 AIR EAU MASE 1
T314020109 THERMOSTAT 2
T314020323 SLEEVE 3
T314020330 THERMO COVER MASERATI 2 LTR 1
T314020331 THERMO O RING 2
T314020343 THERMO HOUSING GASKET (BITURBO 7
T314020344 THERMO COVER SPIDER 2
T314020345 THERMO HOUSING SPIDER 3
T314020347 O RING 222E 2
T314020351 THERMOSTAT BOX 1
T314020353 GASKET 1
T314022349 O RING 222E 3
T314022358 THERMO COVER 222E 1
T314025011 WATER PUMP 2
T314050365 PLUG 1
T314120005 RADIATOR GRILLE 2
T314220312 WASHER MASERATI 2ltr 4
T314520145 LOCK LH MASERATI 1
T314520151 PIN STRIKER 2
T314520158 WEATHERSTRIP 1
T314520159 GASKET 2
T314520160 CHANNEL RH DOOR ASSY MASE 1
T314520427 KNOB 1
T314530101 PANEL DOOR LH 222E 1
T314530102 PANEL DOOR RH 222E 1
T314620101 CLUTCH DEVICE 2
T314820323 GASKET 1
T314820325 GASKET 1
T314820336 SEAL RING 3
T315020103 ROLLER BRG CAGE 2
T315020105 BEARING CAGE 2
T315020106 BEARING SPIDER 2
T315020107 BEARING BALL 2
T315020110 BEARING SPIDER 2
T315020111 SEAL RING 3
T315020112 BEARING 1
T315020311 BRACE 7
T315020326 SPRING 1
T315020335 SYNCHRO REV 1ST 1
T315020338 REVERSE AND FIRST SYNCHRO 1
T315020345 SEAL RING 3
T315020385 LIQUID GASKET 1
T315220318 GASKET 1
T315220327 RING 1
T315220328 GASKET 1
T315520008 OVERHAUL KIT A/C COMPRESSOR 1
T315520009 MAGNETIC CLUTCH 1
T315520102 FILTER ASSY A/C 1
T315520103 PIPE 1
T315520128 EXH FREON VALVE 1
T315520169 VALVE NON RETURN 430 1
T315520175 PRESSURE SWITCH 3
T315520350 3-WAY CONNECTOR 1
T315520356 WATER OUTLET 1
T315520444 O RING 1
T315522144 COCK COMPLEX MASERATI 430 1
T315553179 PIPE RUBBER 1
T316020103 DROP CENTRE BEARING MASERA 1
T316220106 BRACKET DIFF MASERATI 1
T316220365 GASKET MASERATI 222E 3
T316320103 LEFT HAND SEALING BUMPER 2
T316320204 RIGHT HAND REAR BUMPER SIDE 2
T316320206 CENTRAL SEAL BUMPER 2
T316327103 SEALING L/H 222E 1
T316327104 SEALING BUMPER R/H 4
T316327203 MOULDING 1
T316327204 MOULDING 1
T316327206 MOULDING 1
T316353119 CLAMP BOARD FRT SPIDER 1
T316353219 CLAMP BOARD SPIDER 2 1
T316620107 SUPPORT ELASTIC FRT MASERATI 2
T316620110 BUFFER 2
T316620112 BUFFER 4
T316620113 SUPPORT 4
T316620119 LEFT HAND LOWER SUSPENSION 1
T316620120 RIGHT HAND LOWER SUSPENSION 2
T316620305 SUPPORT 1
T316620306 RIGHT HAND ARM TO CONTROL 1
T316620352 BRACKET STABILIZER MASERATI 1
T316620354 INSULATOR 5
T316620355 INSULATOR 4
T316620360 BUSH 8
T316653104 STRUT ASSY MASERATI 1
T317020104 SHOCK ABSORBER REAR MAS 2
T317020105 SHOCK ABSORBERS 2
T317020117 UPPER SPRING CAP MASERATI3 1
T317220106 BADGE FOR WHEEL RIM 5
T317220311 BEARING 2
T317220312 BEARING 2
T317220314 NUT 4
T317220343 BEARING 2
T317220344 BEARING 4
T317220346 RING 2
T317420112 MASTER CYLINDER 1
T317720013 WEATHERSTRIP SET 1
T317720016 KIT FINISHER (RAD GRILLE ) SP 2
T317720105 GLASS DR L/H MASERATI 2. 1
T317720106 GLASS DR R/H MASERATI 1
T317720132 GLASS QTR R/H MASERATI 2. 1
T317720138 GLASS REAR FIXED MASERATI 2
T317720304 MOULDING RH SIDE MASERATI 1
T317720308 MOULDING 5
T317720337 FINISHER R/H 1
T317720338 FINISHER L/H 2
T317720372 MOULDING 2
T317820123 RACK & PINION MASERATI 420 1
T317820320 LOWER SUPPORT 1
T317820341 SEAL RING 4
T317820342 SEAL RING 7
T317832371 BELT 3
T318020109 LEVER HAND BRAKE 1
T318020118 CABLE HAND BRAKE 2
T318020120 TIE ROD 1
T318020320 ROD CLUTCH 1
T318020324 PAWL 2
T318020325 SPRING 2
T318020327 PIN 2
T318120328 SEAL 1
T318120329 GROOVED NUT 1
T318120345 GUARD (BITURBO SPYDER) 2
T318120346 SUPPORT (BITURBO SPYDER) 2
T318220009 CABLE 5
T318320301 LEFT HAND HEADLAMP BEZEL 1
T318320302 RIGHT HAND HEADLAMP BEZEL 3
T318350301 BEZEL H/LAMP L/H 222E 1
T318350302 BEZEL H/LAMP R/H 222E 1
T319020003 CLAMP 4
T319020101 EXH TUBE 1
T319020102 EXH TUBE 1
T319020106 TUBE CONNECTORS 1
T319020109 SILENCER 3
T319020300 EXHAUST HANGER 16
T319030312 SPRING 2
T319220007 FUEL PLUG 430 1
T319220124 FUEL REGULATOR 3
T319220140 PRESSURE REGULATOR (MASE 1
T320220035 BRAKE PAD SET REAR 3
T320250033 CUP & CLAMP MASERATI 2.8 3
T320250034 ROD & JOINT KIT 1
T320256037 BRAKE PAD SET FRT 2 1
T322310163 CANOPY DASH 1
T323127103 HEADLAMP ASSY L\H 22 3
T323127104 HEADLAMP ASSY R/H 222E 2
T323320172 SWITCH COMBINATION 1
T323320195 ACTUATOR 1
T323350150 SWITCH ELECT WINDER MASERATI 3
T324032320 HOSE 222E 7
T324032325 SLEEVE 4
T324156005 RADIATOR GRILLE 222E 1
T324156108 FINISH PROFILE 222E 1
T324530101 DOOR FRONT L/H 1
T324530102 RH FR DOOR 1
T324550022 HANDLE FR CHROME 1
T324620111 CLUTCH COVER 2
T324620112 CLUTCH PLATE 2
T325520172 VACUUM PUMP 430 1
T325570250 PIPE RETURN 222E 2
T327720300 MOULDING 30
T327720301 MOULDING 1
T327720303 MOULDING 1
T327720304 MOULDING 1
T327720619 MOULD END CAP 7
T327870320 LOWER SUPPORT MASERA 1
T328270010 ACC CABLE MASERATI 2 1
T329232355 GASKET 2
T334720100 LUGGAGE BOOT 1
T334720118 TRUNK STRUT 2
T336320340 TRUNK DRIVE 2
T337700021 WDW MOTOR 1
T337700022 WDW MOTOR 1
T337720027 LEFT HAND GLASS 2
T337720028 RIGHT HAND GLASS 1
T337720313 GLASS QTR FRT L/H MASERATI 2 1
T337720314 GLASS QTR R/H SPIDER 2
T337720329 GLASS DR R/H MASERATI 2.5 1
T337720330 GLASS DR L/H 1
T337720337 FINISHER LH 1
T337720339 GASKET 4
T337720369 BRUTT LH ASSY MASERATI 4
T337720370 BRUTT RH ASSY MASERATI 1
T337920003 CANOPY (BLUE ) MASERATI 1
T337920013 HANDLE LH MASERATI 1
T338320306 GASKET UPPER MASERATI 1
T338320328 GASKET 2
T339220409 FUEL FILTER MASERATI 5
T340600008 GASKET SET O/HAUL 1
T343200107 IGNITION BOX MASE 2
T343700150 INJECTION BOX MASE 1
T344600111 PRESSURE PLATE 222E 2
T344600112 CLUTCH DISC 222E 3
T397870225 RACK & PINION MASERATI 2.5 L 1
T399000110 REAR PIPE RH 222E 1
T399002119 COVER LH SILENCER MASERATI 1
T399002120 COVER RH SILENCER MASERATI 2 1
T429041100 OIL FILTER 5
T470045601 THERMOSTAT MASERATI 2
T473362201 GASKET EXHAUST 6
T53451375 BLANK KEYS 9
T58841309 SECURITY ROD 2
T87760012 BULB 2
Julian Formosa is offline   Reply With Quote
The Following User Says Thank You to Julian Formosa For This Useful Post:
pkayhko (11-09-2011)
Old 06-01-2008, 04:44 PM   #2
ODENDAL
Re: Parts for sale
Ii AM INTERESTED IN THE FOLLOWING PARTS FOR MY MASERATI 222SE `1992:
T312420100
T313121109
T314520145
T318350301
T318350302
I am also looking for a rear view mirror and a manifold.
Regards
Dirk Odendal
RSA
ODENDAL is offline   Reply With Quote
Old 06-16-2015, 07:29 AM   #3
inkjet2
Re: Parts for sale
Interested in part 337920003 Blue Canopy
inkjet2 is offline   Reply With Quote
Old 05-30-2016, 08:27 AM   #4
MOBIL3318
Re: Parts for sale
Hi,
I`m interested in parts: 316620110, 316620112, 316620113, 316620360, 325520172. If, of course, you still have this parts.
Regards
Roman
MOBIL3318 is offline   Reply With Quote
Old 09-03-2018, 05:50 AM   #5
Gaurdians1878
Re: Parts for sale
HI i am interested in the following parts 312550301, 312550302, 314353100, 314750100, can you reply asap with prices. thanks
Gaurdians1878 is offline   Reply With Quote
Old 02-07-2022, 11:45 AM   #6
Tfischer99
Hey there, 314020323 I had a fire and need this part :)
Hi there, after an unfortunate fire my car needs a few spare parts.
DO you still have 314020323 available by any chance?
thank you so much!
Best,
Tom Fischer
Europe
Tfischer99 is offline   Reply With Quote
Search this Thread:
