| Latest | 0 Rplys |
11-19-2016, 12:43 PM | #1 | |
In the 200 Club
4H for 2 Hours at 65 MPH
1996 Chevrolet Cheyenne
3/4 Ton, 4X4 Extended Cab, Long Box
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i |
11-19-2016, 12:50 PM | #2 | |
Your worst nightmare
Re: 4H for 2 Hours at 65 MPH
The binding is just a symptom of the front CV's in 4WD
The Following User Says Thank You to Stealthee For This Useful Post: |
tinkering (11-19-2016)
11-19-2016, 12:57 PM | #3 | |
In the 200 Club
Thanks,
So are the CVs worn out or can a guy needle some grease into them or...? I see there are 4 CVs, one on each end of each shaft. I am going to price out a couple of new shafts, and compare that to replacing the CVs on the old shafts. I will check my local APS and compare to online suppliers. I figure both sides have to be done?... because the binding occurs when backing up left and right.
11-19-2016, 01:35 PM | #4 | |
I don't think replacing them will do anything. The binding is just a symptom that occurs. Low speeds with the wheel turned will cause what you felt.
tinkering (11-20-2016)
11-20-2016, 06:27 PM | #5 | |
In the 200 Club
11-23-2016, 11:41 PM | #6 | |
Had a conversation similar to this on a forum (this one???) a few weeks ago.
It's not the front-axle CVs that are binding, it's a transfer case effect based on the front wheels turning a different radius from the rear wheels. Odd that you only feel it in reverse. Mine does it forwards and backwards. You're going to be inspecting the brakes anyway; it's worth looking at the rear shoes to see if there's a problem. In the olden days, the park brake was moderately effective forward, less-so backwards. The drum brakes were of the duo-servo (self-energizing) design, and they energized better forward than backward. My 1/2-ton used twin-leading-shoe brakes in the rear until I crammed a 3/4-ton axle under the back. The bigger axle uses the duo-servo design.
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
11-23-2016, 11:57 PM | #7 |
11-24-2016, 07:12 AM | #8 | |
I would check all the drive train fluids for condition .
transfer case could be making noise,.. |
