Go Back   Automotive Forums .com Car Chat > Toyota > 4Runner/GX470
Old 01-07-2016, 01:34 AM   #46
MikeCStig
Re: please help. 94 4runner wont start. not starter or battery
The only ideas I can think of that haven't been mentioned are the solenoid and the starter itself.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
MikeCStig is offline   Reply With Quote
Old 03-06-2016, 10:01 PM   #47
Peppermint
Post Re: please help. 94 4runner wont start. not starter or battery
I have read a lot of the posts on this chat and I have noticed many do not refer to the owners manual. Just by reading it has help in guiding me to where items are on my truck. There are 3 fuze boxes on the 95 4Runner, just by reading. The manual has helped me solve simple problems.
Peppermint is offline   Reply With Quote
Old 11-03-2016, 09:32 AM   #48
Brandonhouda
Some help would be great! i have a 95 4runner Sr5. A few months ago had to replace starter and everything was great afterwards. yesterday went out and started my truck to warm up and turned on running lights, everything was working well and went back inside. came out about 5 mins later and the passenger side front and back running lights were not working,(head lights, break lights and turning signals still worked) thought it was a fuse but no fuses were blown and bulbs are still good. today went out to start my truck and turned the key and click.... all power to everything was gone! not sure if these two instances have anything to so with each other. i have checked the battery and even tried other battery and no go! I can jump the truck from another car and runs. I have read through this forum and wanted to see what people are thinking. please help I love my truck!
Brandonhouda is offline   Reply With Quote
Old 11-04-2016, 10:09 PM   #49
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Check the wire from the battery positive terminal to the fuse/relay box next to the battery. Many times this wire or the connection becomes bad and causes weird electrical problems.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 05-24-2017, 09:58 AM   #50
Jleggyota
Re: 93 22RE won"t start after cables installed backwards
93 22RE. Needed a battery. Son started to install backwards. Positive cable started to smoke a little before I noticed it. It did not burn. Now the starter will not turn over, no interior accessory power (radio, turn signals, dome light, etc..) the headlights still work and the door buzzer. It will push start and run fine. Any suggestions????????
Jleggyota is offline   Reply With Quote
