Go Back   Automotive Forums .com Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-01-2006, 01:56 PM   #1
adamus
weak breaks in the traffic hit
Hi,
Is this normal that break pedal goes down much lower then usually
in the traffic hit? I thought it were disk pads and I changed them
but doesn't look like it helped. Funny thing is that looks like more
noticable if AC is on...
thanks
adamus is offline   Reply With Quote
Old 08-04-2006, 11:32 PM   #2
Tofuboy
Tofuboy's Avatar
Re: weak breaks in the traffic hit
1) check for brake fluid leaks.
2) bleed or replace your brake fluid.
AC has nothing to do with your brakes.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Tofuboy is offline   Reply With Quote
Old 08-04-2006, 11:44 PM   #3
corning_d3
Send a message via Yahoo to corning_d3
A/C could affect braking if it's idling the engine up. It sounds like your brake fluid needs to flushed/replaced. How old is the car?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
corning_d3 is offline   Reply With Quote
Old 08-05-2006, 01:05 AM   #4
Tofuboy
Tofuboy's Avatar
Now how in the world does the engine idling at hight rpm to compensating AC load will affect braking?
95 Civic EX
83 Toyota Starlet
Old 08-05-2006, 01:17 AM   #5
corning_d3
Because the engine is idling higher than normal......Like giving it more gas while braking...
Old 08-05-2006, 03:11 AM   #6
Tofuboy
Tofuboy's Avatar
The RPM compensation is to prevent the engine from stalling at idle when the AC compressor is engage, it is only effective during idling and not when the engine is driving the vehicle (not to mention it's only a few hundred RPM difference).
When the car is braking from speed and the transmission is engage, the car's momentum is actually driving the engine not the other way around, so the AC will not affect the braking (and remember the compensation is only during idle).
Please don't confuse other members by posting incorrect information.
95 Civic EX
83 Toyota Starlet
Old 08-05-2006, 03:16 AM   #7
corning_d3
That's not incorrect.. When decellerating with the a/c off, my engine shuts off the injectors, allowing the catalytic converter to be replenished with O2. With the air on, however, the injectors continue to fire while decellerating. I too notice poorer braking performance with the A/C engaged.
Old 08-05-2006, 04:21 AM   #8
Tofuboy
Tofuboy's Avatar
That's another incorrect info; injectors will not shut off unless you turn the ignition key off. The ECU will only decrease the volume of fuel being inject into the engine and try to keep the A/F ratio to 14.7 to 1 during deceleration.
Again the AC RPM compensation ONLY HAPPENS AT IDLE and the extra few hundred RPM power is being use by the AC compressor, that is why it’s call compensation not extra boost. That few hundred RPM power will never able to reach the wheel considering all the gear reductions and friction it has to go though
Even if you are decelerating with the transmission engage at idle rpm (most unlikely), the power flow is reverse (from wheel to engine), therefore brakes are not affected.
95 Civic EX
83 Toyota Starlet
Old 05-11-2012, 12:03 PM   #9
andrrewdamien
Weak breaks could be very dangerous in traffic rush. It could be a major problem and could invite very big accident. So if you don't have a good safety it may cost you very costly. It is always a good to have a better protection in advance.
advertising removed by moderator
andrrewdamien is offline   Reply With Quote
Old 05-12-2012, 01:51 PM   #10
somick
somick's Avatar
This thread is SIX YEARS OLD!
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
