07-25-2015, 06:26 PM | #1 | |
ABS/No trac warning lights
I have a 2005 Century that show ABS and No Trac warning lights. I use an electrical cleaner spray (without lube) on the front passenger side ABS connector spraying male & female ends. The warning lights don't reappear and brakes seem to function normally.
Then a few months later the same warning lights appear, I repeat the spray and everything seems to return to normal again. This process has been going on for about a year. Can anyone recommend anything beyond the spray that might result in a longer fix? |
07-25-2015, 08:38 PM | #2 | |
Re: ABS/No trac warning lights
When you disconnect the harness from the sensor, and shake the harness, does water come out?
07-26-2015, 07:52 AM | #3 | |
I didn't notice any water. The connector is mounted in a vertical position.
Thanks for the reply. |
