Old 04-02-2016, 04:25 PM   #61
Scale-Master
Scale-Master's Avatar
Re: ’73 Camaro
I made copies of the Kicker 6X9 speakers for the rear…
Rubber Heartbeat floor mats for the front…
And the velour dot pattern for the three factory seats…
The dash still needs the gauges, but most of the painted details are done. The stereo is a Kenwood KRC2008 and the face is a custom decal. The burl wood trim is hand painted.
The silver paint had worn through the dash trim on my car so I repainted it blue (and the Camaro script) to go with the exterior. I also added the A/C vents and made a non-manual transmission brake pedal.
Scale-Master is offline   Reply With Quote
Old 04-10-2016, 07:23 PM   #62
Scale-Master
Re: ’73 Camaro
I made decals for the gauges; the lighting isn’t the best so the shadows are blocking the small ones, (fuel, amps, temp and clock gauges).
I didn’t make a decal for the tach. Seemed like a waste of time drawing it and then putting the AutoMeter tach in front of it. I can’t see the factory tach in the real car. (I don’t even know if it still works.)
Old 05-28-2016, 07:38 PM   #63
Scale-Master
Re: ’73 Camaro
Shot the base color (Admiral/Cloisonnι) blue from the original touch up paint I had for the real car, with a coat of intra-clear to seal it.
Old 06-04-2016, 12:27 PM   #64
Scale-Master
Re: ’73 Camaro
The sealer-clear coat was sanded out but not polished or waxed. Custom made stripe decals have been applied.
On the real car I chose to paint the stripes with hard point corners on the inboard edges (like a Chevelle) instead of the factory stock round radiuses. I think it accents the pointy nose better.
Still a few more decals to add before clearing it…
Old 07-03-2016, 03:55 PM   #65
Scale-Master
Re: ’73 Camaro
All the decals were applied a week or two ago and since I was shooting my Corvette, I shot the clear on this too.
Old 08-04-2016, 03:42 PM   #66
Scale-Master
Re: ’73 Camaro
I machined a set of aftermarket Auto Meter gauges from aluminum.
A vacuum gauge, tach, and oil press & water temp.
I made decals for the faces and installed the tach and vacuum gauge.
Old 08-17-2016, 10:14 PM   #67
Scale-Master
Re: ’73 Camaro
Originally I planned to make the exhaust pipes out of solder, so I filled in the mounting holes in the chassis. But after looking at the kit’s pipes, even though it is for the single crossover style muffler, I saw it would be much easier to modify those parts into what my car has.
I used the left over turbo mufflers from the AMT ’66 Nova (I used to build another one of my cars) and chopped and spliced the Camaro pipes to fit sans the single muffler. The cross-over pipe was made from a piece of one of the headers that didn’t work. It is all pinned together with aluminum rod.
Base coat of silver ready for proper coloring…
Old 08-18-2016, 03:38 PM   #68
Scale-Master
Re: ’73 Camaro
Exhaust system has been colored and weathered and dry installed with the suspension sub-assemblies.
Old 08-18-2016, 05:41 PM   #69
Scale-Master
Re: ’73 Camaro
The water temp and oil pressure gauges I machined a couple weeks ago have been installed in their little under dash panel. The switch for the driving lights has been added to where the cigarette lighter used to be. A crush sleeve was machined from aluminum and added between the steering wheel and column. I’m calling the dash done for now.
Old 08-18-2016, 07:13 PM   #70
da_ashman
da_ashman's Avatar
Re: ’73 Camaro
Looking Awesome!!!
da_ashman is offline   Reply With Quote
The Following User Says Thank You to da_ashman For This Useful Post:
Scale-Master (08-22-2016)
Old 08-22-2016, 04:34 PM   #71
Scale-Master
Re: ’73 Camaro
I made the Wink mirror by milling some smoke colored plexiglass to make the base for the mirror panels. Then boxed them with some 0.010 sheet styrene.
The mirror faces are made of Mylar.
And a custom decal to replicate the stickers on the front side…
Old 09-03-2016, 03:25 PM   #72
Scale-Master
Re: ’73 Camaro
I finally got around to polishing some of the body parts. First I sanded the hood stripes smooth then hit it with some Tamiya wax.
Old 09-03-2016, 10:07 PM   #73
malscar
malscar's Avatar
Re: ’73 Camaro
Now that looks better than a real bonnet.
malscar is offline   Reply With Quote
Old 09-12-2016, 09:56 AM   #74
Scale-Master
Re: ’73 Camaro
Finally got the chrome trim done and waxed the body.
Old 09-12-2016, 06:15 PM   #75
OWhite3
Re: ’73 Camaro
Good lord, that looks fantastic!
OWhite3 is offline   Reply With Quote
