| Latest | 0 Rplys |
08-14-2012, 08:13 AM | #76 |
Re: 97 TAHOE 5.7L VORTEC WON'T START...GM Merlin ideas?
08-14-2012, 08:22 AM | #77 |
08-14-2012, 08:28 AM | #78 | |
I've never heard the fuel pump last week turn back on. Was hoping just got a defective fuel pump. I've checked the ground and the fuel relay and they both checked out good. Haven't checked anything else yet since it worked for a week.
08-14-2012, 08:37 AM | #79 | ||
splicing in the new connectors to the car wiring need be soldered and heat shrink to prevent voltage drop. the suction tube must fit tight. if the pump sucks air it will fail. with the pump removed you must determine what failed. low voltage /low fuel level will kill the pump quickly. with the pump working what was the fuel pressures ? could have restricted return/supply lines fuel pressure test would show this . |
08-14-2012, 09:03 AM | #80 | ||
05-04-2013, 09:22 AM | #81 | |
i am having a problem with my 2000 cadillac escalade 5.7l vortec it idles good and if i give it throttle slowly it will drive fine but when i give it alot of gas it starts sputtering and doesnt have any power ive checked the fuel pressure its good running at 52lbs and ive replace coil wires and plugs i hooked a computer up to it and it wasnt pulling anything but o2 sensor codes but i dont have cats on it so thats why its pulling those codes when i mash the throttle it acts like its loading up or doesnt have any fuel but my pressure is great the guy that hooked the computer up is a family friend thats a mechanic and he said all of the sensors look good tps and the other day i was driving on the highway and it got worse i could only go like 30mph and when i killed it at home it wouldnt start so i replaced the coil and it started again but im still having the same problem no power and sputtering can someone please help me and i checked the distrubitor cap and it looks good
05-04-2013, 02:49 PM | #82 | |
i would start new post.......may be an injector problem.
05-04-2013, 07:59 PM | #83 |
01-02-2014, 10:03 PM | #84 | |
2000 chevorlet Tahoe 5.7 engine won't start after numerous repairs
I have a 2000 Chevrolet Tahoe limited edition Z71 5.7 liter engine. I have had it for almost 2yrs. since I brought it I have been doing repairs to it because it will run for a few weeks then breakdown again. over the pass few months I have replaced the fuel pump , fuel filter, ignition pressure regulator, crankshaft position sensor, camshaft position sensor, coil pack and did a complete tune up. But it still won't start I have read the Chevrolet Manuel books for ideas of what could be cause of my truck not starting and have changed everything that I could think of. PLEASE HELP ME FIX TRUCK ASAP !!!!!!!!!!!!
01-03-2014, 01:56 PM | #85 | ||
Re: 2000 chevorlet Tahoe 5.7 engine won't start after numerous repairs
01-05-2014, 05:16 PM | #86 | |
Hey rhandwor I CAN'T take my truck to be scanned because it WON'T START AT ALL. I have tried spraying quick start in the engine a few times. it will start after I spay the quick start in the engine and stay on for a few second then cut off.
01-05-2014, 05:40 PM | #87 | |
01-05-2014, 05:45 PM | #88 | ||
350 requires 62-65 psi key on engine off. go get gauge and see what ya gut ! |
01-05-2014, 05:57 PM | #89 |
01-05-2014, 06:12 PM | #90 | ||
Are you getting any sign of your anti theft system being on a man spent hours on the forum and his would start run around 1 minute and then shut down. After reading all of your problems I would at least watch your light for an indication. This truck also has a fuel pressure regulator. I never heard of an ignition pressure regulator. Use a noid light try Advanced or Auto Zone for a loaner. I think the anti theft will shut off power to the injectors. |
Thread Tools | |
