| Latest | 0 Rplys |
03-06-2002, 12:50 PM | #1 | |
Air bag light!!
Anyone have their Air bag light flashing??
09-07-2003, 05:53 PM | #2 | |
Hit the door ligh switch 5 times really fast.
09-17-2003, 11:49 AM | #3 | ||
Re: Air bag light!!
Were you being serious with this or were you just being funny. I felt funny trying it. Does anyone else have a fix for this besides a $70 trip to the dealership? Thanks, jpiiii |
09-17-2003, 08:36 PM | #4 | |
Bigity Bam link Try it! I havent had the problem yet but I know what to do, sorry it was a little more difficult than what I had said earlier.
09-18-2003, 08:07 AM | #5 | |
Re: Air bag light!!
Outstanding!!! It really worked. Thanks so much.
The first time I did it I did not wait for the light to blink down the 3 seconds 2 seconds etc. I waited long enough for it to do that and it worked! Thanks Again, J.P. |
10-27-2003, 12:13 PM | #6 | |
Re: Re: Air bag light!!
We are trying to put out the air bag light in a Nissan Navara in the UK. We have tried the method as described in this section, with no luck. The mechanic is feeling really silly now, any ideas. Does anyone know another fix and also where the sensors are.
11-18-2003, 09:17 PM | #7 | ||
Re: Re: Re: Air bag light!!
I also have a 99 Nissan Frontier with the airbag light flashing. We tried the pushing of the door button 5 times, and it's still flashing. Is there a secret to it? Please let me know. |
12-06-2003, 03:33 PM | #8 | |
Re: Air bag light!!
I Am Absolutely Sure This Is Correct: I Work At A Family-owned Nissan Dealership.
1- Put The Key In The Ignition And Turn To Acces-not On And Do Not Start The Car! 2-within 10 Sec Push The Door Switch 7 Times 3-watch The Airbag Light It Should Flash A Code In A Series Form. ----- Pause ----- And It Will Repeat. (if You Aren't Sure How To Count The Code Just Reset It. If There Is A Serious Or Real Problem, It Will Come Right Back On When You Start The Car And It Will Remain On.) 4-now Turn Off The Car Remove The Key...now Put The Key Back In The Ignition And Start The Car. It Will Come On And Should Turn Off After About 8-10 Seconds.
95 nissan 300zx convertible 99 nissan frontier se-v6 91 jeep wrangler 4.0l (project) |
01-28-2004, 01:17 AM | #9 | |
Re: Air bag light!!
2001 Frontier-reset Airbag Light.
1. Open Drivers Door. 2. Turn Key On Until Airbag Light Comes On. 3. Turn Key Off & Close Door. 2001 Frontier-get Air Bag Codes. 1. Open Drivers Door. 2. Turn Key On Until Air Bag Light Comes On-it Takes Approx. 7 Secs. 3. Turn Key Off & On Within 1 Sec. After Airbag Light Comes On. 4. Repeat This Three Times. These Sequences Will Get You Somewhere. |
02-01-2004, 03:44 PM | #10 | |
Re: Air bag light!!
IT does work! put the key to ON not start, before the air bag light has a chance to flash hit the door swith 7 times and wait, the air bag light should flash once pause flash once pause etc.. now turn the key off and remove it, quickly put the key back in and start, light will come on for a few seconds and shut off, if it doesnt work the first time try a few more time, if it still does not shut off or the flashing is irratic (this means there is a falt code"something wrong" ) take it to a mechanic or you can count the flashes and find out what the problem is...turn THE KEY ON NOT START again hit the door swicth 7 times before it has a chance to start flashing, it will then start to flash in a patern, excample...flash flash pause flash flash flash pause is 23 then call the deilership and ask the service tech what this code means, they will tell you the problem, go from there........good luck
05-24-2004, 10:39 PM | #11 | |
Re: Air bag light!!
the dealer will almost never tell u what the code means, he wont ever make any money.
12-08-2005, 08:10 PM | #12 | |
Airbag light code 18?? for 98 Nissan Frontier?
Okay, I think I got my 98 Nissan Frontier to cough up the diag code. I did the 7 button salute and the Airbag light now does 1 long blink followed by 8 fast blinks. Am I right that this is a 18???
If so, then does anyone have access to the diag codes for this? If so could you PLEASE let me know what this is trying to tell me??? THANKS! Chris Bailey |
07-22-2006, 08:58 AM | #13 | |
Re: Air bag light!!
I tried turning the key to the ON position not the ACC and pushed the driver's door jam switch 7 times and the airbag light went off. It really works!!!!!!!
08-15-2006, 11:49 PM | #14 | |
Re: Air bag light!!
For Nissan Frontier/Navara Specific forums and helpful people, check out:
http://www.clubfrontier.org/ |
08-15-2006, 11:53 PM | #15 | |
Re: Air bag light!!
http://www.clubfrontier.org/ Plenty of good info -- some bad info but with good intentions. |
Thread Tools | |
