| Latest | 0 Rplys |
06-13-2004, 10:03 PM | #16 | |
Re: A/C problem with 1999 malibu
i live in florida. It is really hot right know. Ignoring it is hard to do in Florida. I don't think anybody has fixed this problem. oh well thanks anyway.
06-22-2004, 10:00 AM | #17 | |
I have a 98 malibu ls and had the same problem. They replaced the control under warranty but I didn't ask specifics.
07-06-2004, 03:13 PM | #18 | |
The HVAC control module is a one piece plastic unit consisting of the Blower speed switch, variable temp setting, air delivery position switch, as well as the 4 buttons underneath these switches. It is located directly under the radio. The following link, which is really for replacing the radio, will tell you how to remove the trim around it as well as show the control module without the trim installed.
http://www.carstereohelp.com/stereor...MalibuStrR.htm |
07-06-2004, 03:37 PM | #19 | |
Remove the ignition key trim cover. Pry off with a flat bladed tool.
Gently pull the plate (1) rearward in order to disengage the retainers from the instrument panel (3). Disconnect the cigarette lighter (2) connector. Disconnect the cigarette lighter (2) electrical connector. Remove the trim plate (1). |
07-07-2004, 03:02 PM | #20 | |
control module
The control module is the whole cluster of buttons and dials for the climate system.
Easy to replace, the trim around the whole center stack just snaps off. Then remove the two small screws holding the panel in. Takes about 15 minutes or so, depending on your ability. the part is about $159 from GM, not sure I'd buy from an aftermarket since GM may have updated the part to fix recurring problems and an aftermarket may not have. Hope it helps. |
06-09-2005, 06:48 AM | #21 | |
Banned
Sounds like a recall dont you think? My '98 is doing it too and it was replaced in 01. That one too does the blinky blinky on off.
LAW SUIT!!!!! |
06-09-2005, 07:02 AM | #22 | |
Do not replace the head unit. The problem is almost assuredly dirty contacts. There have been many people on this board, including myself, that had the same problem. Remove the trim, remove the unit, clean it as shown in the link below, and it should work just fine. I have done this and have been flicker-free for over six months, including the past week where it has been 85 degrees, with nearly 100% humidity. Plus this fix is free.
Go to: http://www.automotiveforums.com/vbul...d.php?t=324015
Be true to yourself and you will never fall. |
06-09-2005, 07:24 AM | #23 | ||
I guess I found what fix I'm gonna try first...my wife's had this problem for a while, but has gotten progressively worse in her 2000 Mailibu. She's just been complaining about it agian because the temps here in Michigan have been up in the 90's lately with high 90-100% humidity...it's like August in June... |
06-09-2005, 09:28 AM | #24 | ||
I cleaned it a couple of weeks ago and it now seems to work fine. |
07-20-2005, 02:22 PM | #25 | |
Re: Re: A/C problem with 1999 malibu
You need to be mechanically inclined, have a steady hand, and some patience to fix the problem. The problem is a bad connection on the temperature control between a springy copper metal contact and the carbon plating on the printed circuit board.
You need to remove the black plastic cover around the key hole. With some pushing and pulling you should be able to pop out the grey plastic cover that goes over the radio and AC controls. I cannot remember if the screw at the bottom left of the panel has to be removed in order to completely remove the plastic cover. You may need to start the car to move the gear shifter out of the way so that the gray plastic cover is out of your way. With the ignition off and the keys out: Remove the three AC control knobs. A small flat blade screwdriver to pry under the knobs might help if they seem stuck. Carefully. Remove the two outer screws that secures the AC switch panel to the dash. Very carefully pry the front and back covers apart and be careful not to lose any of the plastic pieces that fall out. If you are really careful none of the plastic buttons will fall out of place. Once the front and rear halves are separated you should be able to see the copper fingers on the center control and the carbon plating on the printed circuit board. Carefully bend the copper fingers outward just a little using your finger. Take a very clean white towel and wipe down the carbon plating. Use a little bit of water on the rag if the carbon plating is visibly dirty. WARNING: Do not use any solvent, anything abrasive, or switch cleaner on the plating and do not rub hard when cleaning the surface. Carefully reassemble the control panel and the reinstall. It usually lasts me about a year or so before the problem reoccurs. I have a 98 Malibu and I have been doing this same procedure for the last 4 years. It is a very bad design flaw and I am sure that GM service centers are making a bundle on this one. Hope this helps. Bill |
08-13-2005, 11:16 PM | #26 | ||
06-11-2007, 11:38 AM | #27 | ||
06-20-2007, 09:16 AM | #28 | ||
All of this is addressed in the link I posted at the top of the page, and is the same in the link above by micosan, but those include pictures. Also, I would not recommend cleaning electric components with water, ever.
06-21-2007, 09:44 PM | #29 | |
This fix worked for me. No more mysterious auto-off-AC. Thanks to OP.
06-25-2007, 07:51 AM | #30 | |
Well, My started to no cool they insterted the computer the fan clutch would not go in the car had freon the controls were fine the Special Fuse it use was ok the relay was ok But the Mech told me it might be the coil So I change the coil and what do you know the ac was working agian with out changing the ac compersor and with out taking it apart which save me in the freon stuff.
opcorn: |
