Old 04-28-2020, 04:28 PM   #1
pgarat
pgarat's Avatar
AAR Eagle Weslake T1G, Dan Gurney, 1967. MFH, 1/20.
Good evening,
Well, well here it is, I finally chosen the superb AAR Eagle Weslake!
It changes from red, but orange and green were not that far away .. the red (s) either either!
The kit is not more complicated than that, but the installation of the rivets promises to be... sporty and time-consuming.
I started by cleaning the parts of the bathtub / chassis, the interior of which is almost invisible once the tub is in place.
Only a small part on each side is polished.
The assembly is, as often, carried out by welding.
The main parts of the V12 are also assembled
And we start to put a little color
The body parts are prepared, adjusted and the locations of the threaded fasteners for solid fastening.
And then, we had to get there, the hull is pierced (0.35) in anticipation of riveting ...
Resin rivets with semi-round head of 0.5 for a tail of 0.3.
There are many!!
Riveting is ... DONE !!
I decided to use rivets of different sizes for different reasons.
For the lateral parts, rivets of 0.5 for the most part, of 0.4 for the outline of the hatches and of 0.8 in aluminum for closing them.
for the upper part of the hull, 0.4 convex / flat head.
These are used for:
- appearance / aesthetics, a kind of scale effect as with painting,
- ease of applying decals.
FYI, there are 1620 ... rivets.
The body parts have been primed and, for some, painted or partially painted
The engine has progressed well
I took the opportunity to work a little on the exhausts and their pronounced traces of heating.
Temporary assembly.
The gearbox is fitted with pretty accessories which I decided to modify: The filter holder, one of the fuel pumps and its filter.
The oil filter covers are redone in aluminum, as is the crankcase of the fuel pump motor.
Machined aluminum and brass hardware is added to provide a little detail to these subsets.
As with the exhaust manifolds, the filters are chemically burnished, then polished and slightly "worn".
Here is the set with the gearbox, painted with a mixture of Gun Metal and semi Gloss Black, 53 and 85 Humbrol.
Make way for the dashboard.
It is primed and painted in my beloved Humbrol 85, a little more diluted than usual and applied in thin coats a little more diffuse to make it slightly less satin.
The counters have their strapping polished.
The decals installed will be covered with "glass" cut to the punch for more realism.
Small machined switches from Top Studio and a few instructions complete the package.
The steering wheel is prepared in the same way as the dashboard.
The original mold is removed and the Allen hardware and its washers installed instead.
A passage of oil allows to shade the colors.
Finally, the tank connection pipe is polished and painted with Candy Electric Blue ZP.
More soon,
Pascal
pgarat is offline   Reply With Quote
The Following User Says Thank You to pgarat For This Useful Post:
mrgixxer (05-14-2020)
Old 04-29-2020, 07:44 AM   #2
lemansnut
Re: AAR Eagle Weslake T1G, Dan Gurney, 1967. MFH, 1/20.
Excellent work so far, can't wait to see more! Such a beautiful car.
Mike
lemansnut is offline   Reply With Quote
The Following 2 Users Say Thank You to lemansnut For This Useful Post:
pgarat (05-05-2020)
Old 05-05-2020, 04:49 PM   #3
pgarat
pgarat's Avatar
Good evening,
Thank you.
Good, the assembly continues quietly.
You have to believe that I didn't have enough to rivet ...
The front partition receives its own in diameter 0.5.
Then also received a good part of its attributes.
The steering rack will be installed later
.. just like the radiator.
It is modified, as well as the pipes connecting to it, in order to weld the fluid inlets / outlets on the body of the radiator.
I brought a little detail with the lateral perforated reinforcements and the manufacturer's plate.
The interior is quickly fitted with a lead wire to simulate the cooling circuit behind the grid and fill the void.
The wheel disc is primed and painted, then finalized, a machined valve installed.
Everything is assembled to the machined rim.
Masking of the bodywork parts before the passage of the sublime blue whose glitter base is extremely fine.
The parts exposed and presented in a white assembly
The hubs are detailed, primed and painted
he original discs are decked out with important grooves that I don't like ... at all!
As for my other models on which I reproduce the scratches of the discs, I made a tool allowing me to maintain them.
The shoulders must be thin, both in diameter and in thickness, in order to be able to machine most of the disc.
The small "jaws" on the second image are those used on a 312F1 for example.
They then went on the lathe to give them a better appearance.
Installed on a wheel for control: could be worse.
The body of the rear shock absorbers is hidden and then painted.
The springs receive a layer of gloss black.
The radiator is painted and the tin solders reproduced according to the images I have.
More soon.
Pascal
Old 05-09-2020, 04:13 PM   #4
pgarat
pgarat's Avatar
Good evening,
The dashboard is finished, wired and the windows installed on the meters.
I did not really manage to take a photo that shows it correctly ... Sorry.
Last masking step before varnish
A shot of white
Disassembly of the parts and installation on their support for the varnish step and presentation in the box so as not to be bothered during this step.
Gravity (EU) sprayed, fresh (Flat Pattern 0.3 Meng)
It dries quietly
It's dry!!
I couldn’t really resist a little "Test Fit"
For fun:
I made a small sheet of carbon this morning to dress small aluminum plates.
They help me to present the pieces for photos, supports for models ...
And, in the afternoon, I decided to make one to present the Eagle with the extra decals and old dry transfers.
It's funny, it relaxes and above all I like it!
I may shoot a layer of clear coat on it tomorrow to standardize everything and protect transfers, more fragile than decals ...
Voilà.
More soon.
Pascal
Old 05-10-2020, 09:16 AM   #5
corrrado
Fantastic build Pascal, really great job overall!!!
corrrado is offline   Reply With Quote
The Following User Says Thank You to corrrado For This Useful Post:
pgarat (05-11-2020)
Old 05-11-2020, 11:15 AM   #6
pgarat
pgarat's Avatar
Hi,
Thank you!
Quite a few tests for the parts to be assembled on the bodywork elements today.
The inside of the nose is painted mat black and the decals installed.
The reinforcement plates of the anchorages of the tie rods are painted in Polished Alu Metal Cote with a paintbrush and slightly polished.
The tank caps are modified and fitted with machined banjo connectors.
It remains to tweak them a little with oils.
Finally, as mentioned yesterday, I varnished the small presentation plate.
It will be used to brighten up the table during exhibitions!
It remains to polish the edge of the 2024 Alu plate.
I might progress back from work ... since the flying club must remain closed! Grrrrr!
Pascal
Old 11-08-2020, 03:26 AM   #7
pgarat
pgarat's Avatar
Hi,
The WIP restarts slowly... but surely.
Connecting session.
The gear box is now installed on the engine.
Done for rear with engine/oil filters, fuel connections, underside tubing from engine to radiator...
Next step will be the front radiator hoses and ducts installation and the rear drive train.
More soon.
Pascal
Old 11-08-2020, 11:26 AM   #8
pgarat
pgarat's Avatar
Good evening,
Well, of course, I lost a part ...
Not that small and yet nowhere to be found after a good part of the evening and the morning...
The part, the lower left anchor of the rear axle push bar (or tie rod ...), has been redone.
I quickly turned a piece of 2x2.25, glued to a plastic card base.
A 0.8 stainless steel tenon and a resin bolt to finish and install.
Quite a few mods and parts for the upper arms to do what I wanted, but it's done.
Sorry for the quality of the photos, but the episode "Carpet Monster" (and I don't even have a carpet!) Made me a little ... irritated.
I hope it will fit anyway.
More soon.
Pascal
Old 11-09-2020, 02:09 PM   #9
pgarat
pgarat's Avatar
Hi,
Progress of the day.
Pipes, ducts and radiator connected and installed.
Lower suspension arms and steering rack in place.
More soon.
Pascal
Old 11-11-2020, 03:52 AM   #10
pgarat
pgarat's Avatar
Bonjour,
A bit of cleaning in the working area...
Front end progress with radiator mounts and air scoops.
Rear completed with anti roll bar and exhausts.
More soon, maybe.
Pascal
Old 11-11-2020, 07:47 AM   #11
lemansnut
Incredible work so far!
Old 11-13-2020, 12:42 PM   #12
pgarat
pgarat's Avatar
Hi,
Thanks a lot
It begins to take shape.
I finished the rear brakes this evening.
Everything is modified and scratched to match my doc.
The cockpit is finished and the upper part of the hull will be glued.
I also added the welds at the junction of the exhaust pipes and the 3 in 1.
Then we have to deal with the front ...
More soon.
Pascal
Old 11-15-2020, 04:03 PM   #13
pgarat
pgarat's Avatar
Hi,
Last details added yesterday...
I can call this one done today.
Sorry for the poor quality pictures...
It’s late, night, tired and lazy to catch the reflex.
I will try to take better ones tomorrow.
Voilà.
Pascal
