10-19-2004, 08:44 PM | #1 | |
Guages and pods HELP!!!
Ok i want to intall a transmission cooler,and i want a temp guage for it. and also maybe a air/fuel guage. SO the question is how do i wire for it and install it on the side on the car!! Thanks -rip
10-19-2004, 11:17 PM | #2 | |
transmission temp gauge, you'd need to get a temperature probe welded into your transmission pan or find some other place to install a probe where it makes contact with your auto tranny fluid. Then you'd run the probe's wires up into the engine bay and through the firewall where it comes out above the brake pedal inside the car. Drop the lower part of the dash and run it up to the a-pillar where you will have your a-pillar gauge pod. Same thing with the a/f gauge, you hook the power up to a power source that turns on when the car does, a ground source, and the white wire will go to your O2 sensor wire which is by your ECU. I still say its pointless to get an A/F gauge unless you have a wideband set up for your car.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
10-20-2004, 02:09 PM | #3 | |
blue + red light magnet
Re: Guages and pods HELP!!!
http://www.stealth316.com/2-wiring-tips.htm -light wiring
http://www.stealth316.com/2-a-pillar-cover.htm -removing a pillar http://www.stealth316.com/2-autometer3373.htm -installing gauge in a pillar These may help a bit
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Thread Tools | |
