Go Back   Automotive Forums .com Car Chat > Oldsmobile > Silhouette
Old 05-28-2010, 11:17 AM   #1
KnowNot
Angry 99 silouette diagnosis n steps to repair please? H2O in oil
K a little over a month ago the van started smoking or steaming infront of the drivers side. Then on occasion the heater would only blow cold. A few days a go it began to run hot and consume antifreeze without leaking. Now after a day of driving w heater on and filling the resivoir I have water in oil. I need to know whats the possible issue, how to trouble shoot and step by step instructions to fix...Thx
KnowNot is offline   Reply With Quote
Old 05-28-2010, 12:16 PM   #2
Airjer_
Airjer_'s Avatar
Re: 99 silouette diagnosis n steps to repair please? H2O in oil
Sounds like you have the very common and well know lower intake gaskets leaking. These are also know to pop head gaskets when they overheat.
If the oil is milky than stop driving it. The main bearings are very sensitive to water contamination in the oil.
Airjer_ is offline   Reply With Quote
Old 05-28-2010, 08:25 PM   #3
KnowNot
Red face Re: 99 silouette diagnosis n steps to repair please? H2O in oil
and how does one begin to fix that...tear down procedure?
Old 06-01-2010, 12:45 PM   #4
dewaynep
A step-by-step procedure is a little beyond the scope of the forum, but a single vehicle subscription to alldata will give you step by step instructions as well as torque values, etc... You may also be able to get the information on Autozone's website, they own alldata.
dewaynep is offline   Reply With Quote
Old 06-22-2010, 07:05 PM   #5
KnowNot
k guess its gas in oil as ive been told...will K&W block seal fix this issue for now?
Old 06-22-2010, 09:55 PM   #6
roadrunner2
Additives won't work.
All the info you need to repair this is posted at the start of this thread under "Important: 3.4L intake gasket.....'
The problem with doing nothing is not knowing when you're finished.
roadrunner2 is offline   Reply With Quote
Old 06-23-2010, 01:38 PM   #7
dewaynep
Gas only has a few ways to get in the oil. The most prominent being a leaky injector. I think we need to know exactly what happened that had you start looking for water or gas in your oil.
Tags
coolant , gasket , overheating
