Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 07-03-2012, 07:52 PM   #1
500hpgtx
500hpgtx's Avatar
Need male pin for large connector 3.8L asap
The large connector at rear acted up again. This time when I moved it, I must have found one of the bad wires. It arced to ground. I just knew it blew the PCM fuse. Wire is very short . removed pin. Need at least 1 new male pin.
Probably extractor would help and additional male and female pins.
P.S.--I think the mad welder only repaired this harness. It looks a little melted and several wires at connector look melted as well.....everybody enjoy the 4th in US....i am not sure I will...cheers KEV
500hpgtx is offline   Reply With Quote
Old 07-03-2012, 11:38 PM   #2
Jeffrv
Jeffrv's Avatar
Re: Need male pin for large connector 3.8L asap
I just had a pin replaced on that connector, done by GM dealer. As you noticed, does require specialized tools to remove and replace the connectors. Otherwise, try NAPA or similar outlets for tools/connector kits, I think they can be obtained aftermarket, but not cheap
Jeff
Jeffrv is offline   Reply With Quote
The Following User Says Thank You to Jeffrv For This Useful Post:
500hpgtx (07-04-2012)
Old 07-04-2012, 10:19 AM   #3
500hpgtx
500hpgtx's Avatar
With the tremendours heat wave in Chicago area, I ended up splicing around the connector. I hate note doing a factory job, but wife is constantly running around in it.
Funny thing..we brought our son home in it as a newborn...now he is learning to drive in it...have a safe 4th of july guys...kev
Old 07-04-2012, 05:38 PM   #4
Jrs3800
Sometimes Kev, working around the problem may solve it for life.... But I do understand wanting it to look like factory...lol
Jrs3800 is offline   Reply With Quote
3.8l thermactor pump mount? democrazy17 Performance 0 06-27-2011 07:48 PM
2003 3.8L Engine VIN Location ChevyCelebrity Impala | Impala SS 1 04-29-2011 11:56 AM
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 07:56 AM
2000 SEL 3.8l Battery Cable Hot !! Nox Windstar 2 06-12-2010 12:06 AM
Life expectancy for a 91 3.8L V6? need to find out what kind of life she's got left 91MercSable3.8L Sable 4 05-18-2004 10:28 PM
