Go Back   Automotive Forums .com Car Chat > Dodge > Ram Van
Old 03-02-2010, 08:27 AM   #16
alloro
Re: 1994 B350 5.9L V8, runs rough and pops
Originally Posted by bigj-dog View Post
As soon as the temp starts to climb, it pops out the exhaust and lopes very badly at idle.
hundreds of new sensors.
Does that include a new 2-wire coolant temperature sensor? (Not the 1-wire one for the gauge.)
alloro is offline   Reply With Quote
Old 03-02-2010, 10:21 AM   #17
bigj-dog
bigj-dog's Avatar
Yep, that's the temp sensor we replaced, with no change. Does anyone have the Mopar instructions for timing the distributor? The instructions i have say to position the distributor as close to the switching point as possible, but if you are turning the dist., it switches from 0 to 5v at one point, then if you turn it back the other way, it switches from 5v to 0 at a different point. I set it exactly in the middle of the 2 switching points. Is that correct?
bigj-dog is offline   Reply With Quote
Old 03-05-2010, 11:35 PM   #18
hundahunta
try block off the egr. if you thinks it's timing just start the vehicle loosen the bolt a little and turn it slowy until it runs fine, what does the plugs look like
hundahunta is offline   Reply With Quote
Old 03-05-2010, 11:41 PM   #19
hundahunta
what happened to the code 27 have you checked that. have you also checked for a plenum manifold vacuum leak??
Old 03-06-2010, 10:20 AM   #20
bigj-dog
bigj-dog's Avatar
Brought the mt2500 back out and found that the crank sensor was bad. Changed it out and it's back to good. Looked it it first, but you could tell that it had been out of there and the owner said it had been replaced. Too bad it didn't show up earlier, woulda saved a lot of dickin' around. thanks for all the help everybody.
Old 03-06-2010, 11:58 AM   #21
alloro
One thing that irritates me about OBD-II is that there is no crank sensor checking or trouble code. That's a major oversight IMO.
Old 10-25-2014, 11:23 PM   #22
sanramonfamer
I have 1993 B350 5.9L V8 360 engine. From time to time the engine stalled while driving, other times the engine just won't start. The battery is charged, and it cranks but won't fire up. Sometimes I need to jump start from another fully charged car. CEL showed error code 27. Cleaned IAD, tested sparks, fuel pressure test showed good PSI reading. Finally, I replaced the crankshaft position sensor, it is fixed.
sanramonfamer is offline   Reply With Quote
