| Latest | 0 Rplys |
08-05-2011, 06:07 PM | #1 | |
2006 KIA Sorento mis firing
Cylinder 1,3, and 5 are misfiring. How do i fix this?
08-09-2011, 06:36 AM | #2 | |
Re: 2006 KIA Sorento mis firing
My 2006 has 3 coils and 3 plug wires one coil plugs on top of a plug and also has a plug for a plug wire. Look at the wiring diagram.
Remove the plastic cap on the engine. Their is a metal cover that runs along both sides of the engine. Remove the covers unplug the wires and use an ohm meter. Ohm each plug wire they should about 1/2 scale. If no reading repair or replace. Depending on the mileage check or replace plugs. Northern or some parts stores have a light you plug into the coil and the other end on the wire. If any coil isn't firing the plug if the plug wires are good replace. LIS20610 is such a tester. is one type use google search for a picture. http://www.ebay.com/ Sells plug wires and coils also tester but the tester is high priced. Remember each coil fires two plugs. Last edited by rhandwor; 08-09-2011 at 06:49 PM. |
08-09-2011, 08:47 PM | #3 | |
Its highly unlikely you have an ignition coil issue or a spark plug wire issue because cyl 1 plug wire is controlled by cyl 2,4 or 6 coil and the same for 3 and 5(not sure the companion cylinders). Cyl 1,3 and 5 are on bank 1 (pass side). You have a common factor causing the missfires on bank 1. This could be caused by a number of things. engine timing could be off(timing belt), a blown cyl head gasket or warped cyl head, an air leak in intake system is only a few problems. The timing is not easy to check because of the p/s and alt bracket you would have to remove to check camshaft marks. If you have an exhaust gas tester test the coolant first to check for blown head gasket. I would then check for an air leak on bank 1. silicone spray works well along with a can of brake cleaner(you will hear a raise in rpm if there is a leak). Be careful with the spray because you can have fireworks if you hit a hot manifold or arcing plug wire. If no problems found there I would then check the camshaft timing. If you have limited access to tools or limited knowledge of vehicles I would take it to your kia dealership. They can fix it faster and more than likely cheaper because they know the vehicle better. This is not a cut and dried common problem with the sorento.
The Following User Says Thank You to ryancoates40 For This Useful Post: |
Devendra95 (08-30-2011)
08-29-2011, 01:32 PM | #4 | |
my sorento has lost power!!! at idle it shakes now and it has now acceleration. It starts up a little slower also. I hear some clicking sound only when im in drive and press on the gas. I stopped and put it in neutral and revvd it up and i dont hear it. I even tried it in park, still nothing. Just when i drive do i hear it. Im hoping its just plugs and wires. any suggestions??
08-30-2011, 07:27 AM | #5 | |
Thanks. i fixed it.
08-30-2011, 07:29 AM | #6 | ||
If so, use the scan tool and tell me the code. Also, how many miles did it finish? |
08-30-2011, 02:29 PM | #7 |
Thread Tools | |
