| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
11-28-2002, 12:52 PM | #1 | |
5g Civic b16a Axles?
I bought a B16a first gen engine and I got a 5G civic, the engine came with tranny (S1), ECU (PR3 non obd), and motor mounts (not in a perfect condition).
What else do I need to the swap??? I don't know about the axles, will my 5g civic axles fit in the swap??? thanks. |
11-29-2002, 05:29 AM | #2 | |
No the b's use intermediate shafts you need the axles from that series motor.You also need a cable to hydralic clutch adapter.And don't forget b series shiftlinkage
11-29-2002, 07:34 AM | #3 | |
My tranny got the internal joint, even with that I need the axles???
Thanks |
11-29-2002, 07:48 AM | #4 | |
If you have a b16a1,a2,a3 or whatever you need the axles that came with the motor if you didn't get them you need to source them froma same series engine or aftermarket producer.Internal joint!!??????Huh
11-29-2002, 08:25 AM | #5 | |
I mean the internal part of the axle, the part that goes into the tranny one of the marked parts of the picture.
11-30-2002, 02:17 AM | #6 | |
That is how all hondas are.Do you have the other shaft(intermediate)because only one of those will actually go into the tranny(passengerside).The other connects to the inter. shaft and that goes to the tranny(drivers side).
12-02-2002, 11:46 AM | #7 | |
Thanks a lot for your help
Yeap, I got the intermmediate shaft, Do I still need the Integra axles or can I use the civic ones??? |
12-02-2002, 11:23 PM | #8 | |
You need to use axles from a b16a the axles from a 5th gen are to long and don't accept the intermidaite shaft.Also the spline count is different into the tranny.You can use teg axles as long as they're from a b series or 99si or 97 delsol vtec axles.or you can contact www.raxles.com they have axles just for this swap driver and passanger side for 159 a piece.That is what I am doing cuz I don't have time to look for stock replacements.You can also get them from honda for a little cheaper.
