Go Back   Automotive Forums .com Car Chat > Ford > Crown Victoria
Old 09-07-2015, 03:39 PM   #1
pimblac78
Question 89 crown victoria tailshaft has a hole in it
Could I just replace the tailshaft or do I need a new transmission and could I replace it myself or do I need to take it to a shop thanks and god bless....
pimblac78 is offline   Reply With Quote
Old 09-07-2015, 06:27 PM   #2
DeltaP
Re: 89 crown victoria tailshaft has a hole in it
That's an AOD trans. There's the tailshaft housing, rear shaft support bushing,rear seal,housing mounting gasket. Sensors in the housing to be removed and installed in the new housing. The trans has to be removed for access.
DeltaP is offline   Reply With Quote
Old 09-07-2015, 06:49 PM   #3
pimblac78
Exclamation Re: 89 crown victoria tailshaft has a hole in it
So as far as needing a new transmission...all I have to do is drop the transmission and check to see if the yoke or drive shaft is bent first...and then change only the bell housing and I'm good
Old 09-07-2015, 06:53 PM   #4
pimblac78
Question Re: 89 crown victoria tailshaft has a hole in it
So what do you think cause the hole in the drive shaft...because I was getting some vibration when I started driving but it went away after a few seconds. ..and also will it be hard to change the tailshaft housing. ..thanks so much for your help..
Old 09-07-2015, 07:37 PM   #5
liya_leacree
then take it to a shop. Good luck.
[Signature removed by moderator]
liya_leacree is offline   Reply With Quote
