Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 06-18-2015, 04:05 PM   #1
phipps
1999 Silverado Power Mirrors Troubleshoot
I have a 1999 Silverado that the power mirrors are not working. Does anyone have troubleshooting tips?
Thanks,
Gary
phipps is offline   Reply With Quote
Old 06-19-2015, 08:16 AM   #2
j cAT
Re: 1999 Silverado Power Mirrors Troubleshoot
Thanks,
Gary
the reason these do not work most times is the control pad is dirty . remove open pad and clean circuit /pad control with some rubbing alcohol and a cotton swap gently.
my 2000 had this issue when new still works now but I did have to clean it after a few years ...
the other issue with these mirrors is they fall off. there is a very cheap piece of metal used to hold them in place I installed a self tapping screw to lock in this retainer washer no more mirrors falling off...
j cAT is offline   Reply With Quote
The Following User Says Thank You to j cAT For This Useful Post:
MikeD268 (06-22-2015)
Old 06-19-2015, 09:24 AM   #3
phipps
Thanks for the reply. That would make sense. I was fiddling with it this morning and if I wiggle the pad enough I got the mirrors to move up, but nothing else.
Does the switch bezel just pop out or do I need to remove the door panel?
Old 06-19-2015, 10:57 AM   #4
j cAT
this pops off the assy with all the switches.. no door panel removal required .
then the removal of the mirror switch pops apart for you to clean up the cir board/pads..
what can happen is pushing down hard wiggle the pad can wear out this ...so when it is not work right clean it up to avoid this..
Old 06-19-2015, 12:20 PM   #5
phipps
Thanks. I will give it a shot before I buy a new one.
Old 06-20-2015, 04:59 PM   #6
phipps
I tore the switch apart and cleaned it today. Both mirrors now work!!!
One caution, the little metal contacts for the selector switch fell out and I put them in backwards. Tore it back apart and flipped them around the right way and everything works like it should.
Thanks for the suggestion! Saved me a few bucks.
Old 06-21-2015, 08:59 AM   #7
j cAT
It is a good cheap fix and you will have to do this again because of the design Gm made which does not protect this from the environment ..
Old 07-06-2015, 05:34 PM   #8
johnbradshow
I had the same problem before and the dealership fixed it in 10 mins just by swapping a blown fuse. You should check your fuse box for blown one as well before doing anything else... just 2 mins quick checkup job!
johnbradshow is offline   Reply With Quote
Old 07-06-2015, 06:57 PM   #9
j cAT
I guess it is possible power to this may have caused the problem . The switch / control pad is what all , have had fail , due to the lack of protection from the elements. with the NBS models... lets say you did indeed have a fuse blown cause your loss of the mirror operation , then were was the short circuit , that the dealership found ? The poster did fix the problem , for just a short amount of effort to clean the pads ...
