06-18-2015, 04:05 PM | #1 | |
1999 Silverado Power Mirrors Troubleshoot
I have a 1999 Silverado that the power mirrors are not working. Does anyone have troubleshooting tips?
Thanks, Gary |
06-19-2015, 08:16 AM | #2 | ||
Re: 1999 Silverado Power Mirrors Troubleshoot
my 2000 had this issue when new still works now but I did have to clean it after a few years ... the other issue with these mirrors is they fall off. there is a very cheap piece of metal used to hold them in place I installed a self tapping screw to lock in this retainer washer no more mirrors falling off... |
The Following User Says Thank You to j cAT For This Useful Post: |
MikeD268 (06-22-2015)
06-19-2015, 09:24 AM | #3 | |
Thanks for the reply. That would make sense. I was fiddling with it this morning and if I wiggle the pad enough I got the mirrors to move up, but nothing else.
Does the switch bezel just pop out or do I need to remove the door panel? |
06-19-2015, 10:57 AM | #4 | ||
then the removal of the mirror switch pops apart for you to clean up the cir board/pads.. what can happen is pushing down hard wiggle the pad can wear out this ...so when it is not work right clean it up to avoid this.. |
06-19-2015, 12:20 PM | #5 | |
Thanks. I will give it a shot before I buy a new one.
06-20-2015, 04:59 PM | #6 | |
I tore the switch apart and cleaned it today. Both mirrors now work!!!
One caution, the little metal contacts for the selector switch fell out and I put them in backwards. Tore it back apart and flipped them around the right way and everything works like it should. Thanks for the suggestion! Saved me a few bucks. |
06-21-2015, 08:59 AM | #7 | ||
07-06-2015, 05:34 PM | #8 | |
I had the same problem before and the dealership fixed it in 10 mins just by swapping a blown fuse. You should check your fuse box for blown one as well before doing anything else... just 2 mins quick checkup job!
07-06-2015, 06:57 PM | #9 | |
I guess it is possible power to this may have caused the problem . The switch / control pad is what all , have had fail , due to the lack of protection from the elements. with the NBS models... lets say you did indeed have a fuse blown cause your loss of the mirror operation , then were was the short circuit , that the dealership found ? The poster did fix the problem , for just a short amount of effort to clean the pads ...
