Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-11-2016, 03:09 PM   #1
44dave44
Different tire sizes on rear dually...problems??
Odd question. Will running different tire sizes cause any stress to drivetrain or suspension? My thinking it will be easier on the suspension, if anything, and nothing on the drivetrain since each side is even.
eg: 285/70/17 on the inners and 275/70/17 (maybe even 265)on the outers.
Possibly P rated on the inner and E on the outer (to retain durability)
I'm trying to improve the ride since my utility truck isn't used for heavy weight and my stuff gets bounced around too much. Rather not touch the suspension.
I know I know the inners will get worn faster but that's fine I'll replace them as it goes. Besides, as it stands now with identical sizes, the outers get worn about 25% faster. May counter that some as well.
Not a 4x4.
44dave44 is offline   Reply With Quote
Old 09-12-2016, 06:49 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: Different tire sizes on rear dually...problems??
All 8 of the drive tires on the dumptruck I drive are the same size.
If unlike sizes worked, it would have unlike size.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 09-29-2016, 10:30 AM   #3
Stale Trooper
Stale Trooper's Avatar
[quote=44dave44;7189860]Odd question. Will running different tire sizes cause any stress to drivetrain or suspension? My thinking it will be easier on the suspension, if anything, and nothing on the drivetrain since each side is even.
Think about this: I used to work for a county fire department, the department mechanic changed out 2 tires on the rear of one of our water tankers (single axle, dual wheels) he put the new tires on the inside of the duals, the old tires on the outsides. the next fire run the truck responded to it rolled, killing the driver. the cause was pointed out in the accident investigation. Photos showed the outer tires were completely off the ground when the vehicle was at rest. That being said, even if you put the bigger (newer) tires on the outside, they are going to be worked harder, because the inner tires are not carrying as much of the load as the outers are, causing the outers to wear out at a faster rate, resulting in potential blow outs. The good side of that would be, you wouldn't have to remove a good tire to change the flat.
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Stale Trooper is offline   Reply With Quote
The Following User Says Thank You to Stale Trooper For This Useful Post:
Chris Stewart (09-30-2016)
Old 10-02-2016, 08:31 PM   #4
Chris Stewart
AF - Advisor
Wow, that was a glaring example although I regret the loss of a fine Fireman,
Thanks ST!
