Go Back   Automotive Forums .com Car Chat > Ford > Excursion
Old 10-13-2004, 08:28 PM   #1
duneswest
#6 fuse keeps blowing on 2000 Excursion
#6 fuse runs overhead computer, turn signals, rear a/c and back up lights. I replaced it with 15 amp fuse and after a few days it blows again. There is no rhyme or reason when it blows. You can run signal, rear a/c all day long and it won't blow. Then all of a sudden it goes out. Sometimes when the a/c, back up lights and signals are off.
The manual says a 15 amp is the proper fuse. Could it be they spec out a fuse too low in amps?
Any suggestions?
duneswest is offline   Reply With Quote
Old 10-15-2004, 12:37 PM   #2
rivguy
Send a message via Yahoo to rivguy
Re: #6 fuse keeps blowing on 2000 Excursion
do you have signal mirrors?
-=-=-DANE-=-=-
rivguy is offline   Reply With Quote
Old 10-17-2004, 04:21 PM   #3
duneswest
No signal mirrors.
It seem the problem started after we had the passenger side power window replaced due to a break in. This is the window on the middle seat. The window was changed out and the fuse was blown after we got the car back. I thought it was something simple like a fuse so I did not take it back to the shop. But it obviously is more than a bad fuse.
Old 07-24-2012, 02:18 PM   #4
paulshort67
Did you ever find out what the problem was with the fuse? in your excursion the number 6 fuse
paulshort67 is offline   Reply With Quote
Old 07-24-2012, 08:39 PM   #5
danielsatur
How doe's the window work?
Even though other circuits are not being used, the control module + sensors demand power.
If there's 3- circuits to a fuse, try isolating 1 or 2 of the circuits out of loop by a disconnect!
12volts/15 amp fuse = .8 ohms
danielsatur is offline   Reply With Quote
Old 08-06-2012, 02:43 PM   #6
kklgpadgett
Sounds like a short in wiring. Pull panel on the door the window was replaced. also follow the wire by wire color to the fuse and disconet on on end check with tester.
kklgpadgett is offline   Reply With Quote
