Old 10-23-2011, 10:19 AM   #16
mike@af
Captain Over Engineer
mike@af's Avatar
Re: Saab Aero-X 1/6
Those carbon ceramic discs are amazing! Great work, and brilliant idea! The rest of your build is just as magnificent. Can't wait to see more.
-Mike
mike.lawrence@automotiveforums.com | AutomotiveForums.com | Flickr Gallery
mike@af is offline   Reply With Quote
Old 10-23-2011, 06:25 PM   #17
hirg
Re: Saab Aero-X 1/6
my God!!!!!!
hirg is offline   Reply With Quote
Old 11-16-2011, 05:03 PM   #18
kaho
kaho's Avatar
Re: Saab Aero-X 1/6
You are officially my new scratchbuild deity! The brake rotors are genius! Was this how you made your brake pads too?
kaho is offline   Reply With Quote
Old 11-17-2011, 04:00 AM   #19
crisjr
crisjr's Avatar
Send a message via MSN to crisjr
Re: Saab Aero-X 1/6
Oh my goodness!! this is definitely a thread that should be follow by every modeler!!.. great start.. the rims looks perfect!!.. what paint did you use to get that chrome result??
Cris Jr.
www.scalestreetracer.com
crisjr is offline   Reply With Quote
Old 11-17-2011, 04:54 AM   #20
Fizik
Re: Saab Aero-X 1/6
Thanks!
I actually made new brake rotors already with a bit finer carbon particles and different rotor bell. Looks even better I think. The brake pads are made of black, softer cd case. Easy to cut and after light sanding with fine grit paper I got that result.
For painting the rims I used Alclad polished aluminum over Alclad gloss black base. So I was not after the chrome.
FYI this is my first ever model to make or assemble, so I think I'm the one that should follow other modellers threads. And lately I have, and got some new ideas and techniques which is great! But for this Saab it's a bit too late to put all the new knowledge to use that mostly I have learned in the process of making it. But I'll finish it the way I'm able to and be proud of it when it's sitting behind the glass showcase and say: "I could not buy one, so I made one"
Best regards,
Andreas
Fizik is offline   Reply With Quote
Old 11-22-2011, 04:17 PM   #21
Fizik
Re: Saab Aero-X 1/6
Here are some "behind the scenes" photos. Since I only have two wheels done, I'm working with the rest of them. Just like brake calipers.
The wheel hub is from an rc car and the spokes are cut from 2mm styrene sheet, filed to shape and then baked in an oven for about 30 seconds to make it soft and give the right curve. So, if you ever want to spend 40+ workhours to make a wheel - now you know how it's made...
Best regards,
Andreas
Old 12-09-2011, 06:28 AM   #22
crisjr
crisjr's Avatar
Re: Saab Aero-X 1/6
i wish i could see some more progress on this project
Cris Jr.
Old 01-09-2012, 03:54 PM   #23
Fizik
Re: Saab Aero-X 1/6
As some of you may know, Saab is going through a very difficult phase of its life and has filed for bankruptcy. Why I drive a Saab and what attracts me to this brand is a mixture of many unique ingredients that other car brands do not have or do not mix together the way Saab does.
But even if they really do not make Saabs any more, I will. And through that show my gratitude and deepest respect to people who have made my favorite car recipe.
With that in mind I am trying to spend at least some time I have in the weekends to the model.
New brake disc with smaller carbon particles and with new center part:
Half done exhaust pipe:
And the template for headlight:
But here is a question: I was thinking that the headlights glass could be made by vacuum forming a clear plastic sheet over the template. What I found was that the clear plastic that I'm using is not as easy to manipulate with. It appeared to cool down ultra quickly when taken from the oven or was not soft enough... Does anybody have any experience or suggestions for this kind of process?
Here is the clear plastic used:
Oh, and here is my favorite recipe - and it's all mine....
Best regards,
Andreas
Old 01-10-2012, 02:30 AM   #24
ales
Forza Schumacher
ales's Avatar
Re: Saab Aero-X 1/6
Good to see your model is doing better than Saab itself.
Nice 2-door there! Turbo? (I'm a Volvo guy myself )
Old 01-10-2012, 02:48 AM   #25
Fizik
Re: Saab Aero-X 1/6
It's a 1993 900 Aero. Yes, it's a turbo
Best regards,
Andreas
Old 01-10-2012, 04:25 AM   #26
crisjr
crisjr's Avatar
Re: Saab Aero-X 1/6
Well done so far.. glad to see that you didn't gave up!. i wish i had some experience to share you with regarding to reproducing the glasses.
btw... very nice car.. 1993.. it looks very nice
Cris Jr.
Old 01-10-2012, 05:51 AM   #27
countach79
countach79's Avatar
Re: Saab Aero-X 1/6
crazy!!
countach79 is offline   Reply With Quote
Old 01-12-2012, 08:10 AM   #28
Pascal D
Re: Saab Aero-X 1/6
WOW this is a nice project. Your workmanship is stunning.
Try using the clear plastic from a blister package. Make a mold for the headlights, heat the plastic with a lighter and pull it over the mold.
Sincerely
Pascal
Pascal D is offline   Reply With Quote
Old 01-12-2012, 08:19 AM   #29
914joe
914joe's Avatar
Re: Saab Aero-X 1/6
Some great modeling here!!! I have had success with limited experience vacuforming sheet styrene. I've always had to make a frame that had pins and made holes in the styrene located on the pins so the styrene will strech and not bend & warp when heated. Are you using a vaccum box???
914joe is offline   Reply With Quote
Old 01-30-2012, 03:46 PM   #30
Fizik
Re: Saab Aero-X 1/6
I have not made the vacuum box just yet, but there is no escape from that
But I had some time this weekend and managed to get my hands on the model.
Not much but everything takes me a lot of time.
New brake caliper finish. I wanted them to stand out a bit more since I put a lot of effort into them. But it had to stay modest. The mat gold seems to do the trick. Just the red Brembo decal is missing
All 4 tires and wheels are finally fabricated. (To be painted)
And the two small air intakes next to the headlights are also being made
Best regards,
Andreas
zc swap 1.5 to 1.6 89crxclint '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-20-2010 10:55 AM
Differences between '05 and '06 1.6 Engines? edr_bug Aveo 0 08-06-2009 11:51 PM
2003 Saab Aero Sportswagon mjp 9-5 6 01-07-2007 04:37 PM
Saab Aero X Concept 2006 MonsterBengt Car Rumors & Concepts 7 06-05-2006 12:16 AM
Saab Aero Turbo mr.penguin19 9-5 3 06-29-2004 11:30 PM
Tags
aero , concept , saab
