Go Back   Automotive Forums .com Car Chat > Automotive Art > Car Modeling > WIP - Motorbikes
Old 12-08-2014, 02:30 PM   #16
utzelu
Re: Not another Yamaha Road Star
I didn't take pictures of the WIP for the rims but I can show you the CAD plans. There are three parts: the rim is one piece, then separate parts for the left side hub and right side hub. All three parts are glued together with epoxy.
Thanks and Regards,
utzelu
http://scalemodelsadventures.blogspot.com
utzelu is offline   Reply With Quote
Old 12-29-2014, 03:32 AM   #17
joelwideqvist
Originally Posted by utzelu View Post
Hi everybody,
Last evening I was thinking about modifying the final drive and make it look more realistic. As you know, the kit part is molded as one piece, having together the drive pulleys and belt drive. It would be nice to have them as separate pieces. So I did a search on the web and found out that SDP makes miniature timing belts which should fit just fine: http://www.sdp-si.com/eStore/, part # A 6B18M145030. I think will order few of these to try them.
Do you have any other ideas for drive belts?
Did you order some of those belts? I have a chopper build where I would very much like to find something like that to use for a primary drive.
Other ideas I've found is to use a folded piece of masking tape with small strips of styrene as teeth and then paint the whole shabang black. Tedious work to get those strips placed in a strict pattern though...
/Joel
joelwideqvist is offline   Reply With Quote
Old 01-09-2015, 03:56 PM   #18
utzelu
Hi Joel,
No, I haven't got the belts yet. There was an issue with the post and they had to send them again, internationally. So it will take some time until they arrive. Will post on this thread once I get them.
Thanks and Regards,
utzelu
The Following User Says Thank You to utzelu For This Useful Post:
joelwideqvist (01-10-2015)
Old 01-10-2015, 04:39 AM   #19
ketje
ketje's Avatar
Hi Joel,
I'm also interested how they'll look.
ketje is offline   Reply With Quote
Old 01-17-2015, 12:38 PM   #20
utzelu
Hi all,
I received the belts and they fit perfectly with the kit parts. The belts are 3 mm wide with 1 mm pitch. Some photos to give you an idea how it looks.
Thanks and Regards,
utzelu
Old 01-17-2015, 01:21 PM   #21
joelwideqvist
Perfect, then I'll order some too. Just have to meassure the length accurately. Or perhaps order open ended belts and glue them in place.
How much did they charge you for postage?
Old 01-18-2015, 02:20 AM   #22
utzelu
It is unlikely that you will find the right length but the belt can be glued with super glue. Shipping was $10.
Thanks and Regards,
utzelu
joelwideqvist (01-18-2015)
Old 01-18-2015, 03:41 AM   #23
joelwideqvist
Great, did you order some for the primary as well? In case you did, what width did you choose?
Old 01-18-2015, 07:53 AM   #24
utzelu
Unfortunately I didn't. I forgot. However, I won't need it for the Yamaha build, so I still have time to think about the primary for the next build.
Thanks and Regards,
utzelu
Old 01-18-2015, 09:20 AM   #25
ketje
ketje's Avatar
Hi all,
Nice,
I have to order these for sure.
Ketje
Old 01-23-2015, 04:04 AM   #26
utzelu
I was thinking about using belts for primary on my other project. The issue is, since the belt is usually exposed, how to glue it to size without showing it?
Thanks and Regards,
utzelu
Old 01-23-2015, 12:47 PM   #27
joelwideqvist
If there is no cover what so ever I would glue it below one of the pulleys.
Old 02-04-2015, 03:39 PM   #28
utzelu
Hi all,
Today, I got my motivation back and did some more work on the bike. I have managed to machine the primary drive pulley. It was not necessary but I wanted to do it anyway. I had to grind a special grooving lathe tool for this job, but since I am planning to do more custom bikes in the future, I will use it more than once.
Unlike the kit part, which is supposed to be painted and glued, the machined part will be secured with a micro bolt and nut. So next job is to machine a 2 mm bolt with nut.
Some photos of the pulley and fit:
Thanks for watching
Thanks and Regards,
utzelu
Old 02-05-2015, 03:40 AM   #29
ketje
ketje's Avatar
Looking good !!
Old 02-05-2015, 01:34 PM   #30
joelwideqvist
Great job!
