| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
06-04-2012, 05:26 PM | #31 | |
Re: How strong a magnet should I ducttape to the oil filter?
How about turning your oil filter into an electromagnetic filter with a little DC instead of duct tape.
06-05-2012, 08:39 AM | #32 | ||
"pro's" who don't clean & throw away those magnets- you haven't been arround engine/transmission experts very much how many miles did that transmission go where it performed as designed- without someone dismantling cracking me up have a nice day |
06-05-2012, 08:51 AM | #33 |
12-10-2012, 01:30 PM | #34 | |
That does sound like a good idea I just wouldn't put it on the actual inside.
Most transfer cases have a slot inside the case where you can find a magnet actually. It's a very common part, some transmissions have magnets at different points also, now due to the fact that there are a lot other materials in a transmission that won´t attach to a magnet, I would say it wouldn't make much of a difference.
Andy C [external link removed by moderator] Last edited by CobraTrans; 12-11-2012 at 11:26 AM. |
12-10-2012, 03:03 PM | #35 | ||
the transmission has a magnet inside the pan. I also put a magnet on the bottom of the pan from a large powerful speaker. the front and rear diff have magnets on the drain plugs. the rear cover on the rear diff has a magnet mounted on the inside of the cover. magnets are used all over on this vehicle. oil filter magnet would work to collect any small particles magnetic less than 15 microns. this is something I never have done . if you do this on the oil filter cut the old filter open and report back if it is effective in catching much material. |
12-22-2012, 05:23 PM | #36 | |
any magnet will work and it will help a little bit to catch all the fine materail the the filter dont catch u can get a roll of magnet at any craft store
01-05-2013, 09:10 AM | #37 | |
All and all the effectivness of a magnet is best to be put near the drain plug, my option. Like stated above, probably already has a weaker one.
This is so when your ready to drain your heated oil, simply pull off magnet from the bottom of the oil pan, Open drain and all the collections will wash out. This is if your pan is steel. If you want to see if you have any concerns to deal with, let it drain thru a paper towel or clean rag. If you got some partials then if you have not done a recent repair on the top side, you are either got to change your oil more often or your driving the car too hard for its design perhaps better listen to the engine - it's has to be telling you something is on it's way out. This works on any fluid check by the way.. Is a magnet worth it? My option - For someone who does not maintain their car - it might just delay a pending issue.. about it. With the exception of transmissions and differentials - I agree they should have Magnets, also where you put the magnets will be the first place to start rusting so will need coat for that.. Last edited by Bob Barry; 01-05-2013 at 09:26 AM. Reason: add - newbie learning how to use this forum! |
04-21-2013, 04:33 AM | #38 | |
I know this is an old thread. However, someone might be interested in information about the topic of effectiveness of oil filter magnets.
Most of the comments here seem to be of the opinion, that they are not useful. I beg to differ. I have been a car nuts since before my teenage years, and I am over 60 as I type this. I have been employed as a marine engine mechanic, a race car fabricator (off road racing), and a machinist at an automotive OEM. That does not make me an expert, I am sure some of you have better credentials, this all just goes to demonstrate my long term and serious interest in things automotive. About a decade ago I was a quality control engineer for a company which makes oil filter magnets. My job was specifically to evaluate the effectiveness of our products and new prototype designs. In those day, we manufactured magnetic filtration devices for hydraulic equipment, not automobiles. One day I asked the question of this technology would be effective in automobile engines, and I was tasked with finding the answer to that question. Long story short, we demonstrated that indeed, engine wear could be substantially reduced with properly designed magnets. Due to the increased market size of the automobile segment of the marked as opposed to hydraulic machinery, the company eventually switched over to manufacturing oil filter magnets exclusively. I went on to become Vice President of Engineering before retiring in 2009. With that background, I feel qualified to address the topic. However, instead, I would refer readers to a document that exists on an automotive website, that is well researched and easy to understand. I think this is allowed here, since it is not promoting any specific product, and I no longer have any personal interest in promoting any product. The document does a good job of explaining what oil filter magnets can and cannot do, and gives information on what features make some oil filter magnets superior to others. Are there scams out there? Indeed there are. The document will explain how to spot the difference. It is located at a site called the avenger- valkyrie website in the articles section under oil filter magnets. To answer the OP directly, you do not want to ductape a magnet to you filter. If the magnet is strong enough to be effective, it will not require ductape, but read that article for the details, it should answer all your questions. |
