| Latest | 0 Rplys |
Car Videos Got a crazy video to share? |
09-26-2005, 08:51 AM | #16 | |
Banned
Re: 220MPH on a bike?
I'm going to have to argue you all here. Owning a 600cc CBR I know how fast 100mph feels. Also, I know this history of that bike in that video. You can't see it (but you can hear it), its a completely worked (and on 17psi) motor putting close to 500hp down to the rear wheels. Theres a video floating around somewhere where they dyno queened the thing up to 701hp. I think the speedo could be off perhaps 10mph at worse, but anytime you're putting close to 1hp per 1lb, things get fast. (Imaging stuffing 2700hp into a honda civic)
09-26-2005, 01:31 PM | #17 | |
Banned
that isnt the point, the point is he doesnt have the TRACTION to burry the needle, that quick at that.
when he does another video and holds a gps in his hand and the gps shows 220mph + or - 10mph i will beleive it...untill then i said the gearratio's where changed... |
09-26-2005, 01:33 PM | #18 | |
Banned
and you can stuff 2700 hp into a civic... and id put my truck on it it couldnt hit 220mph that quick, if at all. 220mph via wheel power (not rocket power) is no laughing matter. imagine the difference between 25 and 50mph on a bike, BIG difference... 100 to 200 mph would be even greater id imagine.
09-26-2005, 03:53 PM | #19 | |
You must be confused with an other video, I just saw the gostrider bikes again and these are real 500bhp bikes. And you can easely tell the difference in sound and speed. The video on this toppic never showed a bike anywhere near 220MPH. I guess 180MPH if not less. The guy must have changed gear ratios and you can tell this bike didn't had any where near 500 bhp, the speedo and the rev indictors showed no wheelspin at all. Very unlikely for a 500+bhp bike if you consider the wheely at the start. (he defenately opend the throttle) And a bike with a 1000bhp/ton ratio sounds impressive but including the driver it's going to be a bit less
09-26-2005, 04:04 PM | #20 | |||
Banned
Re: Re: 220MPH on a bike?
10-01-2005, 03:53 AM | #21 | |
I have a busa, that is not 220, what he did was an aftermarket face gauge, Max in 6th gear.. about 190 is 10,500 rpm's. Also by his shift points it looks like he has a larger rear sporcket, which also would account for speed being off. That is about 160mph... 200 look ALOT faster than that, beleave me its not real. Also, a McLaren take a long time to reach 231. Ill post the video later, and you need alot of room. Even with a stock busa you need a mile or so to really reach top end.
Here is a photo of my gauges on the right you can see the speedo, indication the SAME position as the one on the left, The one on the right reads 180 mph and the one on the left reads 220 Oh btw, where the rider shifts from 5-6th is the same point you would shift from 160 Here is a stock hayabusa sprocket, works with a stock hayabusa. Why? becasue the speedo is calibrated to the output shaft of the transmission. The actual speed sensor is located on the cluch/sprocket cover housing located on the right here is your aftermarket sprocket. causing a huge difference in rear wheel speed. the speed sensor would not pick up on that change becasue the chain and the output shaft are still moving at the same speed as before.. Its like changing the rear end in your car, or the tire size and expecting the same speed reading people that think he is doing 220+ are the same people you see looking in car windows to see how fast the car can go by the speedo. BTW where he shifts from 5th to 6th at "210" is the same point you would shift at. at 170, also his rpm gauge is wrong too, where it reads 11,200 rpm's is where 10,200 rpms are at. 10.2 is where your gov is limited to in 6th gear.
10-02-2005, 06:19 AM | #22 | |
http://curl.planetmirror.com/pub/mis...usa-Aarhus.mpg
there is what 187 really looks like... (300 kph)
10-11-2005, 05:31 PM | #23 | |
cant beleive he was doing a wheely at that speed
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines" --2OF9-- (DSM team specialist) ;D #808/1000 |
11-24-2005, 12:55 PM | #24 | ||
probably stemmed from some guy in a fast car goading a biker on a forum and he came up with the vid. the speed it is travelling at is wrong compared to the speedo yeah, it doesnt look as if it gets more than 150, the speed it accelerates from 50-100, 100-150 and 150-200 is the same on the speedo, even i know that aint possible! ive driven at 190mph and scenery goes past you a hell of a lot quicker than that!! when you aint glued to the road not blinking |
11-24-2005, 01:09 PM | #25 | |
Theres a big difference between a car with slick aerodynamics and a bike...
11-24-2005, 01:12 PM | #26 | ||
what did you mean by it? |
11-24-2005, 01:38 PM | #27 | ||
Banned
Re: Re: Re: 220MPH on a bike?
well i may as well defend my view point even if its adead thread...
Traction patch of a McClarin F1 is far greater than the bikes AND had more weight over the traction patch resulting in even greater traction. look at a dragsters tires and look at a motor cycles tires. the traction patch is at least 5 times greater from one wheel and is probably made from a much stickier compound and on a much stickeier road with more weight over its traction area. once agian i will say that there is a thing called the "hand of god" where you can have the power to weight ratio but you just start getting wheel spin at high speed which had resulted in death in some casses due to lack of controll. |
11-24-2005, 01:38 PM | #28 | |
I recall reading somewhere that motorcycle manufactuers tweak the speedometer to say its going faster then it truely is. I believe it was around %10 - %15. That could account for some of the speed.
11-24-2005, 04:54 PM | #29 | |
thats 220 km...look at the gauge and mph is right inside there.
11-24-2005, 10:50 PM | #30 | |||
If bikes were more aerodynamic an 11 second bike would have a huge top speed... http://sportrider.com/tech/146_0106_aero/ Quote:
