Old 10-30-2019, 10:22 PM   #136
360spider
360spider's Avatar
Re: Lola T-70 Mk III
Very tasty bits!
ItalianHorses.net
360spider is offline   Reply With Quote
Old 11-03-2019, 09:22 PM   #137
Scale-Master
Scale-Master's Avatar
I've been working back and forth and back again with 3D designing, old school machining and basic hand building to facilitate better fitting of the soon to be grown parts to help the fit of the end results.
I milled up caliper and rotor "blanks" out of resin to help check tolerances inside the software and to the physical parts I have. I also had to draw up in 3D some of the kit parts I modified for spatial orientation. Here's some screen grabs I took before sent the files off to Fraxional.
Scale-Master is offline   Reply With Quote
Old 11-10-2019, 12:19 PM   #138
lovegt40
ItaloSvensk
lovegt40's Avatar
Great stuff. too nice.
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
lovegt40 is offline   Reply With Quote
Old 11-12-2019, 08:52 PM   #139
Scale-Master
Thanks GT40!
These are the tie-rod ends with adjusters for toe. Brass and aluminum loosely assembled.
Old 11-14-2019, 12:22 PM   #140
Scale-Master
I acid treated them instead of using paint.
Old 11-19-2019, 03:29 PM   #141
GvEman
GvEman's Avatar
Great and informative as always! Your skills are on such a high level witch Really inspires! nice CAD work. We have several printers on work but have not tried them out. What material seems to be best for smooth surfaces? I am suspecting our printers aren’t printing fine enough.
Keep up the awesome work!!
Best Regards
Anton
GvEman is offline   Reply With Quote
Old 11-19-2019, 07:35 PM   #142
Scale-Master
Thanks GvEman.
I am not doing the actual printing, I'm just the designer/artist.
But the parts for this one are done with U.V cure resin. It is much better than the nylon based filament parts I had grown some time ago.
Old 12-08-2019, 09:56 PM   #143
Scale-Master
I got some more of my 3D parts from Fraxional over the weekend. All parts are raw as "grown", but I have cleaned off the supports. Here's a few.
Flywheel with pressure plate & clutch. Small 153 tooth flywheel.
Front side installed in bellhousing.
New corrected Hewland rear transaxle cover.
Engineered to mount with magnets. (I had the bosses for the magnets grown into the part.)
Full engine & transaxle dry fitted together.
Old 12-10-2019, 05:13 PM   #144
Scale-Master
Half shaft yokes 3D printed by Fraxional. The shafts are brass; the larger one has already been treated with acid for the color. Just dry fitted together.
Old 12-24-2019, 11:52 AM   #145
Scale-Master
I took a shot at growing some parts myself. Here's a valve cover. It's hard to capture the details in the clear resin in photos. I plan to cast copies in opaque urethane resin.
Old 12-24-2019, 08:22 PM   #146
freakray
AF Modelrater
Exceptional stuff - I really need to check back more often to keep up with your updates, your work is absolutely inspiring.
AF User Guidelines
freakray is offline   Reply With Quote
Old 12-26-2019, 05:37 PM   #147
Scale-Master
Thanks Ray!!
The alternator parts were grown by Fraxional, but I neglected to send one of the part files so the clear piece is the inner/center section that I grew rather than wait.
Old 12-27-2019, 03:25 PM   #148
Scale-Master
Brake pad masters ready to have a mold made. My 3D files grown by Fraxional.
Old 12-28-2019, 06:04 PM   #149
Scale-Master
I grew the masters of the Wilwood calipers I designed but was not able to get the outsides to look their best without sacrificing the details on the insides where the pads mount.
I machined and hand finished the insides to accept the pads and to fit together.
Fronts on top, rears on the bottom.
Old 12-29-2019, 10:47 PM   #150
360spider
360spider's Avatar
Very nice. Detail work that you do is very cool.
ItalianHorses.net
