Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 04-27-2003, 08:20 AM   #1
fast325it
"oilservice" light on '88 M3
The "oilservice" light just went on in my '88 M3. Anyone know if this is simply a warning that the oil needs to be changed, similar to a mileage counter on a newer BMW? If so, can I reset it? Or, if it's a problem that I need to look into have you any idea what may be the problem? The oil level is good, at the high level mark on the dipstick.
Thanks for any input!
fast325it is offline   Reply With Quote
Old 04-29-2003, 04:50 AM   #2
beamer adam
Cool Oil Service
That oil service light is accompanied by the the lights on the status bar changing from green to yellow and now to red and yellow poissibly. this is to tell you that its time for an oil change and i'm not sure in the case of the m3 but on most other bmws of that era any way it usually comes on after about 6,000 miles although this can vary if the car is left sitting idle too. once the oil is changed you need a special tool to reset the light (can be done by dealer) or can even be done with a paper clip but involes disconnecting the ECU and is far to risky as it could damage the Ecu if you dont know what your doing.:sun:
beamer adam is offline   Reply With Quote
Old 04-29-2003, 10:54 AM   #3
kaoru-tochiro
Banned
kaoru-tochiro's Avatar
Re: Oil Service
or you can just ignore it till it burns itself out.
kaoru-tochiro is offline   Reply With Quote
Old 05-03-2003, 01:47 PM   #4
2L8-IWON
Reset your service lights
http://www.dimmotorsports.com/bmw-resetlightsE30.htm go here you will see how to reset the service lights there. Hope that this helps ya out
2L8-IWON is offline   Reply With Quote
Old 02-25-2004, 03:45 AM   #5
tim_mervik
Re: "oilservice" light on '88 M3
Great tips... thanks. Is this the same for a 525 from '89!
I ahve a light marked EML that popped up.... and wondered if this reset might cure that too....??
Thanks again,
Tim.
tim_mervik is offline   Reply With Quote
