Go Back   Automotive Forums .com Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 10-09-2008, 07:43 AM   #1
Indy Tech
Smile Custom paint work
Link removed by Moderator. Link broken, and linking to other message boards that require you to sign up is prohibited.
Hi lads
Doing a custom pain job on a Range Rover 2005 .
Just finished painting and got the first clear on .
My Question is, which is the best way to put on the next 5 coats of clear as this is what the customer wants.
which grain of paper should i use between each time we clear, he was saying he wants 5 - 7 coats
any help from a good custom painter would be great,
We are using PPG paint and clearcoat
Thanks Indy
indy shop owner/tech
Indy Tech is offline   Reply With Quote
Old 10-10-2008, 05:02 PM   #2
SydwayZ
Re: Custom paint work
You dont allow clear to dry between coats. Put down all your coats at once, allowing 5 to 10 minutes between coats. This allows the clear to 'flow' well. Since you've already applied one coat, flat the entire vehicle with 1500 grit waterpaper and then put down the remaining coats. Another 3 coats will be fine. Then sand down the vehicle with 1500 paper again and polish. I use presta cutting creme followed by meguiars professional speed glaze.
SydwayZ is offline   Reply With Quote
Old 10-29-2008, 04:10 AM   #3
mentel
Racing Forum Moderator
mentel's Avatar
Send a message via ICQ to mentel Send a message via AIM to mentel Send a message via MSN to mentel Send a message via Yahoo to mentel
Actually you allow clear coat 15 minutes between coats for it's flash time. Otherwise you can get imperfections such as fish eye and chemical pop.
mentel is offline   Reply With Quote
Old 11-22-2008, 08:03 AM   #4
Indy Tech
Thanks buddies we used PPG 4000 clear coat
sanded with the 1500 wet between each coat of CC we waited 24 hrs before
sanding as the PPG web site told me to do.
we put on 5 coats and it turned out fantastic i'll post some photos
next week so you can see the finished project
cheers Indy
