| Latest | 0 Rplys |
11-16-2013, 01:04 AM | #1 | |
cylinder 1 and 6 misfire
i have a 2001 dodge ram 1500 v8 5.2 liter engine
i have a cylinder 1 and 6 misfire it takes a while for my truck to start i have to pump the gas pedal to turn on and then it sometimes idles really low around 400-500 rpms when i reverse it dies more frequently i have replaced all the spark plugs, wires, & coils radiator fuel pump oil pump thermostat engine i think my next step is fuel injectors but im not sure? any help would be appreciated |
11-16-2013, 05:51 PM | #2 | |
AF - Advisor
Re: cylinder 1 and 6 misfire
Do you have any codes like the P0301 & P0306?
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
11-16-2013, 11:25 PM | #3 |
11-20-2013, 09:25 PM | #4 | |
AF - Advisor
Hmmm, #1 & #6 are 180 degrees apart in the firing sequence. I wonder if that would have anything to do with the problem?
My '01 manual shows 1 ignition coil for your engine. The 8L V-10 shows 5 ignition coils and #1 & #6 are on the same coil, oddly enough.
Thread Tools | |
