| Latest | 0 Rplys |
02-05-2012, 01:03 PM | #1 | |
2001 accord ex 4 cylinder p1259 vtec malfunction after engine change
i just replaced an engine in a 2001 accord ex with the 2.3 4 cylinder vtech f23a1. After getting the engine installed and running, i noted the radiator cooling fan running with the engine cold and an immediate check engine light with p1259 code. I cleared the light with engine off key on and it immediately returned. I also noted the cooling fan on as soon as ignition was on. I read on another forum about the vtec oil pressure sensor plug being swapped with the water outlet temp b plug. I checked and the water outlet sensor had two plastic prongs that only allowed one of the two plugs to fit. After checking the old motor, i found the water outlet sensor was the same except it didn't have the two plastic prongs. I swapped out the water sensors and swapped the plugs so the green plastic end was on the vtec solenoid and now all is good. I just wanted to post this as I'm sure someone will run into the same problem and hopefully this will help.
02-06-2012, 06:07 PM | #2 | |
Lactose the Intolerant
Re: 2001 accord ex 4 cylinder p1259 vtec malfunction after engine change
Interesting, thanks. Good thing you found a possible answer somewhere...little crap like that can drive you bonkers if you have to whittle down to the cause...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
11-11-2012, 10:50 PM | #3 | |
Thanks dude. That helped a ton. Couldnt find anything for weeks on my problem, then found your post.
