Go Back   Automotive Forums .com Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 02-04-2008, 10:25 AM   #1
Rodrigo072788
strech metal
I was wondering is you can shrink or strech metal in a body line??????
Any thoughts?????
Rodrigo072788 is offline   Reply With Quote
Old 02-08-2008, 09:25 AM   #2
Greenblurr93
Kind of a Big Deal
Greenblurr93's Avatar
Send a message via MSN to Greenblurr93
Re: strech metal
Before i answer this, id like a bit more clarification... what type of body line are you talkin about? and what is the purpose of shrinking or stretching? Are you trying to remove the body line as a way of smoothing out the body panel?
Greenblurr93 is offline   Reply With Quote
Old 02-08-2008, 09:06 PM   #3
eckoman_pdx
Honda God
eckoman_pdx's Avatar
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: strech metal
Are you trying to smooth out body lines? OK shave moldings? Are you trying to gain a slight fender flare? I have seen small fender flares/IE "pulling a fender" done, but if you are trying to shave anything, that's not the way to do it. Post up what you are wanting to do.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
eckoman_pdx is offline   Reply With Quote
Old 02-09-2008, 04:53 PM   #4
CarBeater
Re: strech metal
Body lines are pressed into the steel from the manufacture to add shapes, features, and to provide additional strength to the panel. The stamped body lines create tention on the steel, which work hardens the metal. Therefore, the body lines are the strongest points of the panel. It takes more impact to cause damage on body lines;however, once damaged, it will make the repair more difficult as well.
With that said, metal on a body lines or any other part of the panel may be streched during a collision. The streched metal must be shrunk to its original (pre-accidental) state. If not, the metal will be weaker than it should.
CarBeater is offline   Reply With Quote
