| Latest | 0 Rplys |
Car Buying Q & A Ask a question, get an answer; it's that simple. Visit AutomotiveHelper.com for useful car buying tools and research. Also, check out Vehicle History Reports to help you avoid chances of finding a lemon. |
01-05-2010, 04:09 PM | #31 | |
Re: Are cushy cars boring?
I'm hoping that by the time I buy a new car Ford comes out with some diesel cars here. Would be very interested in a TDI Taurus.
And the mileage on my car is thanks to the standard 2.73 rear end gears. The police interceptors have 3.27 or 3.55s which are nice to get going quickly, but gets quite bit lower mileage.
2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
01-05-2010, 04:25 PM | #32 | ||
Razor Sharp Twit
That's why I specifically talked about a situation where an engine is at its peak in terms of design and opened with "not entirely true". The short of it is that these days, there is a replacement for displacement (it's called forced induction...) but you can't deny/ignore that a bigger engine has benefits. Incidentally, since you mentioned pollution, one thing Honda vtec engines are good at as a by-product of their high power output per litre is that they tend to be much cleaner than most other similar engines. As an example (because I remember it) the old 1998 Honda Accord Type-R's engine was so efficient in it's fuel burning that it was compliant with 2002 Euro emmisions standards. Admittedly it isn't actually that hot at about 230g/kg but it was still much better than nearly any other 4 cylinder in production at the time. Also, some numbers for you. 2.2L 207bhp 0-60: 6.9 31mpg urban 36.2mpg extra urban 29.4mpg combined. Not the highest output 4 cylinder Type-R VTEC but this is supposed to be a family saloon after all. While we're also talking diesels, the Accord 2.2L diesel is possibly one of the finest 4 cylinder diesel engines in production being both ultra refined (for a diesel) and stupidly clean at 153g/kg (or there-abouts). Yes, that's better than the old 1998 VTEC engine. It isn't a sports car but then no sports car I know has these numbers 42.2mpg urban 61.4mpg extra urban 52.3mpg combined. You also asked about the Ford Focus. It's a harder ride than you'd think but at the same time, it isn't affected by it. What I mean is, while you are aware of bumps and ruts, you're never fighting it (or the wheel because of it). Car nerds will tell you that's because of the decent amount of lateral bump soak that the fancy schmancy "Control Blade" (Fordspeak for their 5 point multi-link/trailing arm rear) suspension has. If you've ever read in a magazine about a car's steering constantly talking to you, this is it. You can feel the car has gone over something as the steering wheel does twitch but it rights itself right away so you're not having to correct it. Great car to throw around. Body control is superb. Lean is gradual and understeer can be corrected with a little lift and it doesn't dive hard under heavy braking but at the same time, it isn't as if the car is overly stiff. Definitely a car to test drive with an understanding sales-rep. Not driven any of the faster ones though or the newer ones either, just an old ST170.
AF's Guidelines Read them. __________________ Currently in the process of re-hosting my photos. If any go missing, drop me a PM. |
01-05-2010, 06:50 PM | #33 | ||
01-05-2010, 07:09 PM | #34 | |||
Chrysler 300 V6- 21-28mpg 3,700lb curb weight Nissan Altima 4 cyl. 24-31mpg 3,000lb curb weight a better comparison for the Altima would've been something like a V6 impala 21-32mpg 3,465lb curb weight. even though the Impala weighs a considerable about more and has more horsepower it gets better mileage with its V6
01-05-2010, 10:14 PM | #35 | |
Actually highway EPA for the 2010 CRV 2WD is 28. Given that it weighs just over 3300 Lbs, has a 5 speed OD tranny (turns about 2100 RPM at 70), and its streamlining isn't that bad, I expected more fuel economy than I'm seeing. The last Honda Accord I owned was a new 91 model - a 4 cylinder w/5 speed manual. It never managed to get 30 MPG on trips. The Jag's best to date was on a business trip up into Ohio. With Ohio's lower speed limits, she averaged 32.5 for the trip.
Regards: Oldengineer |
01-06-2010, 07:27 AM | #36 | |
Re: Shpuker,
A lot of extra weight comes with a bigger motor and heavier components to deal with the added torque. And when comparing the Impala V6 to the Altima 4-cyl (which uses a fairly large 2500cc unit) you say the Impala gets better mileage - how do you arrive at this? You mean the highway mileage being 1 mpg better, because if you're referring to the city the Altima still handily out-miles the Impala by a hefty 3 mpg. So if we were proper nerdy mathematicians here, we would combine the numbers and divide to arrive at averages, in which the Altima would still be ahead, even with the biggest 4-cylinder of the group. And as far as the weight, well, that only better explains the proper engineering of the Altima, there's no need for a family sedan to weigh nearly two tons... |
01-06-2010, 07:50 AM | #37 | |
Re: DrunkenMonkey,
You're in England, no? You chaps on that side of the Ocean get a much better Focus than we do, at least for dynamics. I believe the Focus we get in North America is tuned for a cushier, lazier ride, which in this case appeals to me, but it is better suited to our long stretches of open road. While not as 'pretty' as the European car, the 2009 model isn't bad, and on the used market it's a heck of a bargain. I can't speak on Honda diesels, we don't get any. And the Honda/Acura brand is all mixed up over there, where the cars we drive are labeled an Acura are called Honda's in Europe. Your CO2 measurement is cool, the g/km rating. I think eventually we will hop on the bandwagon as fuel efficiency becomes more of a concern, but for now we just rate mileage. It all boils down to money here, to hell with the air quality. But unless I'm mistaken, your congestion tax in London is pretty stupid as well. A V8 twin-turbo BMW 7-series 'hybrid' or Lexus SUV that struggle to get 20 mpg is exempt because of their hybrid status, whereas a 50 mpg gas car like a Mini Cooper must pay because it is not a hybrid...is that correct? Craziness. |
01-06-2010, 11:05 AM | #38 | |
Razor Sharp Twit
couple of things just came to mind
i) we have a different gallon to you guys so the numbers I give are to Imperial Gallon which is about 1.2 of your gallons so any of my mpg figures will have to be multiplied by 1.2 to get it to your mpg. ii) in the UK we hardly ever pay attention to the individual urban/extra urban rating for mpg, instead taking the combined cycle rating (not the average of the two) as the "typical". with respect to the V6 Impala vs Nissan Altima, their combined mpg ratings are approx. 27mpg vs 31mpg. iii) congestion charge. vehicles that are exempt: Alternative fuel vehicles (includes duel fuel/hybrids) Electrically propelled vehicles Vehicles with nine or more seats (i.e a minibus) Motor tricycles Roadside recovery vehicles so yup but bear in mind that mpg isn't the primary concern whereas emmisions is. We also have a co2 based taxing system on cars as well.
01-06-2010, 11:18 AM | #39 | |
Well, I'm from Canada so we use Litres, our maths are going to be way off! Since we use Metric (like the rest of the entire world other than the United States), our fuel economy is measured by litres per 100 Kilometres.
What do you think of the C02 based taxing system? Personally I think its a great idea but it could get complicated, especially if it applies to used cars. For example, people with lesser means usually buy older vehicles which generally use more gas. So if you can't afford a new car, I don't think you should be penalized for having to buy used. Assuming it only applies to new cars, it benefits in several ways by making cars more affordable at the entry level (economy cars), and if you want to cause more pollution buy buying an excessive vehicle, you pay your contributions to help offset it's CO2 production. This system still allows for exotic vehicles, you just have to be willing to pay to offset their impact. Is that about right? |
01-06-2010, 11:54 AM | #40 | |
Razor Sharp Twit
It does only apply to new cars so older cars are still tax based on engine capacity.
In any case, taking all things into account, I still don't see why everyone don't just buy Lotus Elises. Basic Lotus Elise S 1.8L 134 bhp 121 lb/ft 26.6 mpg urban 48.7 extra urban 37 mpg on the combined cycle 179 g/km 5.7 0-60 tops at 127ish mph what more do you want/need? apart from a working hip at 65...
01-06-2010, 01:04 PM | #41 | |
Hmm. Well, it would be a fun toy!
01-06-2010, 10:52 PM | #42 | ||
So we're using 3 different measurements, in 3 different countries.
I agree, everyone buy a Lotus! OR YOU DIE!
