Go Back   Automotive Forums .com Car Chat > Nissan > Titan
Old 05-26-2021, 07:19 PM   #1
eric58
Trailer lights
Greetings all, I have a 2009 Titan, I routinely pull a utility trailer with it. The lights on the trailer stopped working. I replaced the wiring and the lights on the trailer, still not working. I checked 2 fuses in the truck, one was a ten amp labeled trailer tow (located in the larger fuse box) and the other was a 15amp fuse labeled TTow turn (located in the smaller fuse box just forward of the larger fuse box). Both fuses are good but still no lights. I will hook the trailer to a friends truck to check and see if the lights work, but I don’t think that’s it. Does anyone know anything else I should check or have any ideas. Thank you, Eric
eric58 is offline   Reply With Quote
Old 05-27-2021, 06:16 AM   #2
aleekat
Re: Trailer lights
I'd first check if you have voltage at the harness plug. Then I'd verify good ground.
Post back, that's what makes Forums Work.
aleekat is online now   Reply With Quote
Old 05-27-2021, 08:11 AM   #3
eric58
Re: Trailer lights
Thanks, a couple of other people I talked to said to check the ground as well. I appreciate you taking the time to reply.
Old 05-27-2021, 03:55 PM   #4
eric58
Re: Trailer lights
It was the ground, there was not enough bare metal, a little sandpaper and some elbow grease…..Lights!
