Go Back   Automotive Forums .com Car Chat > Toyota > General Discussion
Old 12-24-2016, 08:02 PM   #1
Volunteer871
How do you drive when ice accumulates on the windshield?
I am from The South and have little experience in cold weather driving.
I have regular windshield wipers on a regular car (Toyota Corolla). There was a mixture of snow, hail and rain pouring down. My car was inside a garage and the windshield was fine at first. The mixture of snow, hail and rain turned into pure rain. However, had the mixture of snow, hail and rain kept pouring down, I would have had to pull over and wait. My windshield accumulated ice. Small, flat chunks of ice were spread all over my windshield to the point I could barely see the road in front of me. As my heater heated up inside the cabin the precipitation outside also turned into liquid (rain). I could then see again clearly.
If it is just snowing or just raining, my wipers will work. I haven't driven in the hail before. Does anyone have any suggestions if there is a long-duration mixture of snow, hail and rain falling that makes a car's windshield have very little visibility? I'm not sure what I would do if the conditions continued. Maybe the heater in the cabin would warm up the glass and melt the ice outside. It seems like I am doing something wrong. The moment of no visibility was a concern to me.
Volunteer871 is offline   Reply With Quote
Old 12-24-2016, 09:38 PM   #2
harleyguy
Re: How do you drive when ice accumulates on the windshield?
Defrost is your friend.
harleyguy is offline   Reply With Quote
Old 12-25-2016, 10:08 AM   #3
somick
somick's Avatar
That was the only way I was able to drive in Philadelphia. Your feet are freezing but at least you can see where you are going.
Another solution is move to California...
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 12-27-2016, 07:48 PM   #4
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
The windshield washer fluid normally contains some deicer to help melt ice and snow on the windshield. It gets warm in the engine compartment and helps a lot. Spray periodically on the windshield when driving. Keep it filled. Buy the fluid which is rated the coldest temperature. It contains the most deicer (alcohol).
Defroster use is critical, as noted by the previous posters. Sometimes you actually have to pull over and scrape the windshield with a scraper.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
