Go Back   Automotive Forums .com Car Chat > Cars in General
Old 05-29-2009, 01:40 PM   #1
ShredTheGnar
painting a car
How much could I expect to pay for the paint to paint the car? I just got back from Afghanistan a few weeks ago, so I have a bit of extra cash to finally get some stuff done to my 1993 Mustang Convertible. I am getting it painted, some 5 star wheels, a 5.0 engine, new interior, and sound system. The engine and wheels are coming from a junk yard. I found a wrecked Mustang with the wheels and engine, and they are still in great shape. The rear pf the car however if f'ed up. I won't have to pay for the labor of getting it painted. I have a good friend that teaches auto body at a technical school. She would gladly paint it for me in class as long as I supply the paint. What can I suspect to pay for the paint? I want black paint like in the following link... http://media.motortopia.com/files/41...9/100_0845.jpg
ShredTheGnar is offline   Reply With Quote
Old 05-29-2009, 06:28 PM   #2
ShredTheGnar
Re: painting a car
I mean yellow not black.
Old 05-30-2009, 10:08 PM   #3
97TaurusGuy
97TaurusGuy's Avatar
Send a message via AIM to 97TaurusGuy
Re: painting a car
depends on what type of paint. Too hard to tell otherwise. PPG has a good line called shopline plus. Bring a paint code to your local ppg distributor and tell them you want it in JBP. It is a good product and a good price. Dont forget your thinner, hardener, and clear.
"Save water, shower with a friend"
97TaurusGuy is offline   Reply With Quote
Old 06-17-2009, 09:33 PM   #4
nsxpowered
Re: painting a car
You should be paying around $470 dollars for paint. Labor is the most expensive component to a paint job so I would say she is hooking you up. 1-1/2 gallon of basecoat, black is a cheap color, unless there is metallics in there. If you use good paint which covers good, then 1 gal should be enough. Clearcoat you'll probably need 1.5 gal. Lets say $220 D403 Jet black for basecoat and $250 923-200 for clear. I'm basing prices off Glasurit. Is she using water base or solvent paint? Forgot to add the primer, the cheapest way is a PCL DTM primer which you can skip the metal etching that should run $100 enough for 2 passes, I don't think you'll need a sealer with that primer, it's very good.
1992 NSX
1993 NSX
1998 NSXT
1997 C5 Vette
1999 CLK430
2001 330ci Convt
1994 RX7 Touring
nsxpowered is offline   Reply With Quote
Old 07-13-2009, 09:49 PM   #5
oldblu65
oldblu65's Avatar
Re: painting a car
If you're going with black , you better make sure your body panels are as straight as you can possibly get them ! The black color will magnify any defects you have and they will be very obvious to all . Also , preparation is key to a great paint job .
oldblu65 is offline   Reply With Quote
Old 12-04-2009, 10:22 AM   #6
orangepeel
orangepeel's Avatar
Re: painting a car
It really depends on the type and brand of paint. At least you have a friend in the industry helping you out. I took my '92 Chevy pick-up to a local body shop after welding in a roll pan because they had a fancy paint booth and in the end it cost me $1,200.....I doubt they even used a gallon of paint/primer.
orangepeel is offline   Reply With Quote
Bookmarks
Search this Thread:
