| Latest | 0 Rplys |
10-14-2004, 11:57 AM | #1 | |
No hurtie! I'm new!
Qwik Qvestion about my 2000 Premium edition Zx2.
I know I have to replace my tie rod ends (note to self -no more sharp fast handbrake turns) this weekend and change my oil; BUT - I have this fuel odor in my cabin and I can't figure out why - or where - it is coming from. I clean my injectors with every second oil change (will do so this time around) and I JUST put new Bosch platinum hi-po plugs in her. Tires need to be done, exhaust is allright, no engine light on. Performance has taken a SLIGHT hit, but not enough to be noticed by anyone but me - since I drive her the most. Perchance it could be a missed leak in the exhaust system and I'm just not seeing it? No smell of unburnt fuel in the exhaust vapor, filter and pump are all right. I only have 25, 500 miles on the car (and I am bitchin about having to drive her this winter). Any ideas? Thanks in advance! "Red" |
10-14-2004, 02:50 PM | #2 | |
Banned
Re: No hurtie! I'm new!
auto or manual? clean the fuel filter or just the injectors?
10-14-2004, 03:55 PM | #3 | |
Oh yeah *slaps self in head* Automatic. 0-60 in oh, 6.6 seconds if I stomp on it, dropping it down to D then (D) one I hit 3000 RPMs. *laughs evilly*
I checked the fuel filter, it's fine. The injectors were *JUST* cleaned about a month or two ago when I changed the oil. I'm thinking it might be an exhaust thang. I AM up here in friggin Podunk and it has been a wet summer - and we all know how -sadly - Fords like to rust. The raw gas smell is also prevalent in the trunk (boot) of the car. Perchance it's just a gasket...? Red |
10-14-2004, 04:19 PM | #4 | |
Banned
6.6? lol try 8's or 9's
10-14-2004, 04:32 PM | #5 | |
Lactose the Intolerant
Check the fuel filter and vapor return hoses to the tank.
10-15-2004, 07:55 AM | #6 | |
ahah , Zat all depends on ze drriver of ze car... and how one gaps ze sparrrk plugs!
I can just imagine how fast I would be if I had a standard instead of an automatic! I run 89 octane in her with the plugs gapped in the dead middle of the manufacturer's gap range - when I stomped on her to test the 0-60, the whole front end lifted up and gave a twist before breaking free - just like my old '78 Caprice classic Landau sport coupe. Ah, the feeling... Thinking of putting a cat-back on her and perhaps some cold induction once I can get her minor repairs done (tie rod end, mysterious gas smell - which I think has to do with exhaust. I crawled under it as far as I could without getting my boobs stuck and felt around while it was running - seems to be a bit of a leak just before the converter... agh.) That SHOULD increase my HP from the standard buck-thirty to something a little more -er- respectable. muwhahahah. Red |
10-15-2004, 08:01 AM | #7 | ||
Re: Re: No hurtie! I'm new!
But would not that put up a code in the OBD? I checked and I had no codes. I replaced the fuel filter not less than 3000 miles ago - did the recommended "three oil changes then fuel filter change" that my Ford-lovin mechanic hubby suggested. I should have HIM fix the friggin thing - get a lift from someone and have him look under the chassis. Vapor return hoses.. hmmm. I'll have a look. I do have some undercarriage rust going on *mutters - damn cheap a** metal* so perhaps it's just a matter of replacing a few hoses. I'm at my mechanical limits right now -need to flush the radiator, the auto-tranny and check the brakes -at 25,500 there's a LOT that needs to be done. New rims are on her menu sometime next year - replacing these special all-chrome ones is going to be a bit**. Checked the fuel rail system last night - no leaks there - no leaks when I park. No leaks when I rev her. With the loss of HP (by maybe 10-20 hp) and the gas/exhaust smell I am still leaning to an exhaust problem. I'm changing her oil tomorrow meself, so I'll look again while I have her up on the ramps and see if I can find anything. I'll let y'all know what it is when I find out - thanks for your help! Red |
10-15-2004, 09:39 AM | #8 | |
You might just have an exhaust leak, like you said. Small engines suffer noticeably from losses in back-pressure, particularly in low-end torque.
10-22-2004, 12:31 PM | #9 | |
t'was the vapor return lines, thanks all - fixed it and it toasts Crapaliers to perfection every time! LOL..
Red
---- Red's ride - "Fokker Deuce" Ford Zx2 Premium Edition Grafix: Iron Cross sunshield, kills markings If ya wanna catch me, better use jet fuel! Vanity plate: Freifrau rearwindowgraphic: Du Doch Nicht! *definitely not you!* |
10-24-2004, 10:50 PM | #10 | ||
Banned
Re: Re: Re: No hurtie! I'm new!
any luck with the leak? |
11-10-2004, 12:53 PM | #11 | ||
Re: Re: Re: Re: No hurtie! I'm new!
The vapor returns were a little loose, but nothing to cause the problem smell. Call me a dumb chick. Really. The smell came from an empty bottle of fuel injector cleaner that hubby had left under my seat. Bastard. : Anywho, fixed that, fixed my tie-rods and got new front Touring BF Goodrich tyres. I was DANG lucky I didn't have a blow-out when I saw the shredded steel belts. I found a grainy crappy pic of my car before her modifications.. Here she is in her glory... - at a car show. - with the dog - who never sits IN the car. LOL Better pics once I can get some film developed and make them less than 80k.. Take care +Red+
11-10-2004, 01:23 PM | #12 | |
Banned
my auto looked like that only with the swirlies, then when the tranny went at 20k i traded her on the s/t
11-11-2004, 09:10 AM | #13 | ||
Yeh, I'm thinkin on new rims for her, since these chrome ones are starting to bubble and rot out on me. Now of course, I have to check my air filter. I know Fords hate anything less than 10C or 50F, but this is ridiculous. I've lost significant mileage due to the cold weather (from 35 MPG to about 28-30 MPG highway). I added some DryGas and we'll see if that works. But the HP is really good. Really really good. I can burn Crapaliers in no time flat. LOL. Red
11-11-2004, 12:27 PM | #14 | |
Banned
just watch out for those z24's and ecotecs
11-11-2004, 10:28 PM | #15 | |
bah... she'll learn the hard way... lol
