| Latest | 0 Rplys |
WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
05-25-2012, 01:38 AM | #16 | |
Re: McLaren MP 4/6 Honda - Tamiya 1/12
Cayman - nice to see someone doing one of these with Rob's RBMotion parts - I will follow your thread - John
05-25-2012, 06:20 PM | #17 | |
Works continued.
The valve caps on the lathe sued four electric fittnings (Ø 2.5 mm) of which wires go to the spark plugs. Side tunnels were given a composite of my production (tissue glue and water) Once dry, I wiped the sandpaper. |
05-29-2012, 07:14 PM | #18 | |
Next work on the front shock absorbers
Installation of computers Throttle lineage [/quote] And other details Regards Peter |
05-29-2012, 10:17 PM | #19 | |
This is shaping up as magnificent and unique build. Your work on engine detail and all those CF textures look wonderful.
Great pleasure to follow. Keep up this amazing job you're doing. |
05-30-2012, 08:55 AM | #20 | |
Looking great..!!
Steve Noble |
05-30-2012, 09:07 AM | #21 | |
Very nice clean build . Keep it going.
05-30-2012, 01:12 PM | #22 | |
Are you sure you are not building the real car? Very impressive!
Tim |
06-15-2012, 10:04 AM | #23 | |
Details are joining the whole.
In recent days, with the help of images from the net and Tamiya Perfect Manual details of which unfortunately do not have the Tamiya kit. general view Engine cooling system pipes I made this electronic module I've reconfigured the tank Another electrical connectors |
06-15-2012, 04:27 PM | #24 | |
wow
06-15-2012, 04:44 PM | #25 | |
Beautiful work Cayman - how did you do the finish on the monocoque? it looks like you misted white-silver-or grey onto the black?? how did you get the finished look? - John
06-15-2012, 08:23 PM | #26 | ||
Monocoque painted semi-gloss black and then a mixture of semi-gloss black with gunmetal and with the further distance of about 30cm and again the black semi-gloss and blend again. And so I repeated a few times until I came out a satisfactory result. Peter |
06-16-2012, 02:35 AM | #27 | |
insane!!!!
06-27-2012, 05:55 PM | #28 | |
After careful viewing images from the Internet ,Tamiya Perfect Manual brought out electric cables, not counting the hours spent on the net and looking at photos to make out with cables, but where-where did it.
And so it seems I also did this element of polystyrene (painted Alclad polished aluminum) tubes and caps from the HD. And here the effect Here the work done The left side The right side cockpit The steel plates, tubes and screws from HD also made the thermal shields Together with the engine |
06-27-2012, 06:59 PM | #29 | |
WOW Caymen - beautiful work on the wiring - I don't suppose you have the routing written down on paper do you?? I would love to see it. Very clean build so far - John
07-13-2012, 08:03 PM | #30 | |
Today, brake discs and brake calipers.
Two halves of the brake discs CA glue, excess gathered on a lathe. For a long time I thought about getting a carbon fiber effect. And so one after backing painted metalizer dark iron and then a dense X-10 gun metal spat irregular periods. After drying the friction surfaces gently rubbed with sandpaper and painted with a mixture of semi-gloss and gloss clear. Brake calipers painted SM tytanium gold . Between successive stages was wrapping masking tape which I love. : evil: I added screws, vents and the brake fluid tube connecting the terminals At the stage of the hub assembly ready rockers will Brembo logo, blades of the pads and the brake hose. |
