Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 11-16-2010, 07:21 AM   #1
laray
1995 318I OBD1 access port
A friend of mine has a 95 318I that is idling rough with engine cold or warm. Can you tell me where the OBD1 access port is located? We are hoping the code will help in locating the problem.
laray is offline   Reply With Quote
Old 12-12-2010, 09:20 AM   #2
dark_islight
dark_islight's Avatar
Re: 1995 318I OBD1 access port
How to get the diagnostic codes? (Does not work on all models)
Sit in the driver's seat.
Turn the ignition to the On position, but do not start the engine up.
Immediately depress the accelerator fully and release fully 5 times quickly.
Wait for a few seconds and you will see the Check Engine light flash once, then start it will start to blink. All codes are comprised of 4 digits. The number of blinks corresponds to the fault code. For example, ON then pause, ON ON then pause, ON ON ON ON then pause, ON ON ON then off would be a 1243.
Each four digit code will be flashed sequentially. When the codes start to repeat, all stored codes have been displayed.
Turn the ignition off and check the codes with the table below. 1444 and 2444 means no problem and that is what you hope to find! Good luck!
If this does not work on your model (will only work on some earlier models), you would need the BMW Peake Research Fault Code Reset Tool
BMW Diagnostic Flash Codes
DME Version --> M1.x M1.x M3.1 M3.3 M3.3.1
Malfunction MCU 1 MCU 2
DME Control Unit 1211 2211 1211 1211 1211
Air Mass/Volume Sensor 1215 2215 1215 1215 1215
Throttle Potentiometer 1216 -- 1216 1216 1216
Output Stage, Group #1 -- -- -- 1218 1218
Output Stage, Group #2 -- -- -- 1219 1219
EGO Sensor #1 1221 2221 1221 1221 1221
EGO Sensor #2 -- -- -- 1212 --
Lambda Control #1 1222 2222 1222 1222 1222
Lambda Control #2 -- -- -- 1213 --
Coolant Temp. Sensor 1223 -- 1223 1223 1223
Intake Air Temp. Sensor 1224 -- 1224 1224 1224
Knock Sensor #1 -- -- -- 1225 1225
Knock Sensor #2 -- -- -- 1226 1226
Knock Sensor #3 -- -- -- 1227 --
Knock Sensor #4 -- -- -- 1228 --
Battery Voltage/DME Main Relay 1231 2231 1231 1231 1231
Throttle Idle Switch 1232 2232 -- -- --
Throttle WOT Switch 1233 2233 -- -- --
Speedometer "A" Signal -- -- -- 1234 1234
A/C Compressor cut off -- -- -- 1237 1237
A/C Compressor -- -- -- 1242 1242
Crankshaft Pulse Sensor -- -- -- 1243 1243
Camshaft Sensor -- -- -- 1244 1244
Intervention, AEGS -- -- -- 1245 1245
Ign. Secondary Monitor -- -- -- 1247 1247
Fuel Injectors (group #1) 1251 2251 -- -- --
Fuel Injectors (group #2) 1252 2252 -- -- --
Fuel Injector #1 -- -- 1251 1251 1251
Fuel Injector #2 -- -- 1252 1252 1252
Fuel Injector #3 -- -- 1253 1253 1253
Fuel Injector #4 -- -- 1254 1254 1254
Fuel Injector #5 -- -- 1255 1255 1255
Fuel Injector #6 -- -- 1256 1256 1256
Fuel Injector #7 -- -- -- 1257 --
Fuel Injector #8 -- -- -- 1258 --
Fuel Pump Relay Control 1261 2261 1261 1261 1261
Idle Speed Actuator 1262 -- 1262 1262 1262
Purge Valve 1263 2263 1263 1263 1263
EGO Heater 1264 2264 1264 1264 1264
Fault Lamp (check engine) -- -- -- 1265 1265
VANOS -- -- -- -- 1266
Air Pump Relay Control -- -- -- 1267 1267
Ignition Coil, #1 -- -- -- 1271 1271
Ignition Coil, #2 -- -- -- 1272 1272
Ignition Coil, #3 -- -- -- 1273 1273
Ignition Coil, #4 -- -- -- 1274 1274
Ignition Coil, #5 -- -- -- 1275 1275
Ignition Coil, #6 -- -- -- 1276 1276
Ignition Coil, #7 -- -- -- 1277 --
Ignition Coil, #8 -- -- -- 1278 --
Control Unit Memory Supply -- -- -- 1281 1281
Fault (code) Memory -- -- -- 1282 1282
Fuel Injector Output Stage, no cyl # -- -- 1283 1283 1283
Knock Control Test Pulse -- -- -- 1286 1286
No Failure 1444 2444 1444 1444 1444
dark_islight is offline   Reply With Quote
Access Port for 06 WRX TR MaXXuS Impreza/9-2x/Outback Sport 5 11-03-2006 05:09 PM
1995 318i Door Locks, Fan Motor singring 3 Series 1 11-04-2005 02:00 PM
1995 318i FOG LIGHT???? luxorreb 3 Series 1 04-13-2005 05:00 PM
1995 318is 129k, Need advice, first bmw, Maint costs? drivethruecp 3 Series 1 09-07-2004 12:09 PM
1995 318i 75K Flex 3 Series 3 06-02-2003 12:27 PM
