Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 04-16-2011, 10:59 AM   #1
dwendt1978
dwendt1978's Avatar
93 Metro keeps burning up rear wheel bearings
About every 3000 miles my 93 xfi keeps roasting the back pass. side wheel bearing. It will start to howl so load you can't hear the radio over it.
When I changed the rear brakes I took off the spindle nut and I swear I messed the threads up or something causing this problem. I have torqued it to 129lbs like the manual says and it still does it.
Maybe I'm not packing the bearings well enough, or using wrong kind?? Gotta get ole girl back on the road with 4 dollar gas!
dwendt1978 is offline   Reply With Quote
The Following User Says Thank You to dwendt1978 For This Useful Post:
Atozer (05-03-2011)
Old 04-16-2011, 11:42 AM   #2
Scrapper
AF Premium User
Re: 93 Metro keeps burning up rear wheel bearings
when your replacing wheel bearing are you putting a new race to?
Scrapper is offline   Reply With Quote
Old 04-16-2011, 11:44 AM   #3
dwendt1978
dwendt1978's Avatar
Now I'm starting to find most say only torque to 79lbs or something like that. Maybe I'm causing it.
Old 04-16-2011, 11:47 AM   #4
dwendt1978
dwendt1978's Avatar
You know this is the 3rd set I've put in so I oughta know. I just can't remember (over 1 yr ago) If they came with them then yes I did. But to tell you the truth if I remember right, when I bought the bearings, it was just the bearings and no races.
Old 04-16-2011, 11:56 AM   #5
Scrapper
AF Premium User
ok then i would look up on autozone .com and see the part number on the race.
good luck........
Old 04-17-2011, 01:06 AM   #6
Rooy
Scrapper, you might want to familiarize yourself with the Metro before trying to answer questions about it.
There is no separate race. The rear uses two one-piece single row ball bearings, separated by a spacer.
And yes, you over-torqued them. 129 ft-lbs is for the fronts. The rears get 74 ft-lbs, but some people will even go less than that.
You have the spacer between the bearings, right?
Rooy is offline   Reply With Quote
Old 04-17-2011, 05:23 AM   #7
Woodie83
Woodie83's Avatar
Rooy has got it there with the spacer, that's the source of a lot of bearing failures on Metros. If the spacer is right then the torque goes through the inner race/spacer/inner race. How much torque you apply is not going to matter to the bearing itself, it's not involved. I'd hit the junkyard and get an entire corner, spindle to lug nuts.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Woodie83 is offline   Reply With Quote
Old 04-17-2011, 10:04 AM   #8
dwendt1978
dwendt1978's Avatar
Yes there is a cone shaped spacer in there. I'll get a new set off bearings and try it again torquing to 74lbs. Need to track down a new spindle nut, as mine is torn up from replacing it 4 times.
This bearing issue caused me to park her for over a year.
Old 04-27-2011, 05:04 AM   #9
carpenter_jai
AF Stunt Driver
carpenter_jai's Avatar
Also get the alignment checked. A tire badly out of alignment cooks that wheel bearing within the mileage you're describing. Can even cause the hub nut to loosen up to the point that brakes won't worked. Make sure that if you have replaced that nut a few times that you use a new one cause you need to (scratching my head for the technical term) stake the nut (hit the nut with a cold chisel or big flat head screw driver to make sure it doesn't work itself loose.
Jai
96 3 cylinder Geo Metro (currently being rebuilt)
carpenter_jai is offline   Reply With Quote
Old 04-27-2011, 01:16 PM   #10
Scrapper
AF Premium User
Talking Re: 93 Metro keeps burning up rear wheel bearings
ok your so dam smart why didn't you figure it out your self? you should have known about the torque was way to much and next time get a book.
Old 04-27-2011, 07:45 PM   #11
Rooy
Uh, I'm not the original poster...
Old 04-28-2011, 04:22 AM   #12
Metro Mighty Mouse
Metro Mighty Mouse's Avatar
Sir,
Last warning. The request that you verify your information before posting a repair suggestion is not unreasonable. Your lack of specific information relating to the Metro as well as your apparent disdain for it is not helping anyone and continued acidic comments will not be tolerated on this forum. The people that frequent this forum have years of experience and many have factory manuals, we are capable of helping with pretty much any issue and do not need your uninformed comments to confuse people seeking assistance. Please take it elsewhere or we will start the work to have you removed.
MMM
Metro Mighty Mouse is offline   Reply With Quote
Old 04-28-2011, 04:43 AM   #13
carpenter_jai
AF Stunt Driver
And gee wizz, the even the best of the best make simple mistakes that surprise the people who know them well. Better to assume this then treat a person like they are dumb.
Jai
Old 05-01-2011, 12:53 PM   #14
Scrapper
AF Premium User
ok my bad sorry...end of story to the other guy.
Old 02-11-2012, 01:19 AM   #15
MetroKinsman
Just an item that might be helpful. Just now I checked both of my manuals. One is the Haynes manual and the other is my 1994 factory manual. In both books, if the staked spindle nuts are used, the required torque is 129 ft. lbs. for both the front and the rear applications. My Metro is a 1994 base model. Needless to say, the spacers must be in place. Otherwise the result will probably be disasterous. Since I have never needed to remove the front ones, I can't comment further. However, as far as the races are concerned, I can state that ball bearings in every application I have ever encountered have always been provided both inner and outer races. Ball bearings have to transfer the load via the inner race to steel balls themselves, and then to an outer race. Probably, the outer races are press fit into the brake drums themselves, and when replacement time arrives, outer races will have to be driven out quite carefully and new ones tapped back in, again, quite carefully and evenly.
As a final note: If castellated nuts are used, then the specified torque values do differ. 58 to 86 ft. lbs. for the rear drums, and 108.5 to 195.0 for the drive axle-to- hub nuts. These figures come from the 1994 factory manual.
Best regards,
MetroKinsman
MetroKinsman is offline   Reply With Quote
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 11:27 AM
1991 Metro Rear Wheel Bearing Issue. doug2060 Metro 5 11-22-2010 11:20 PM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 09:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 09:37 AM
Rear wheel bearing LAT Neon | Plymouth Neon 0 09-27-2003 05:03 PM
Bookmarks
Search this Thread:
