| Latest | 0 Rplys |
06-02-2004, 11:41 AM | #16 | |
240SX Guy
Re: Reducing Hydrocarbons (HC)
Check your compression. You should have about 160 if it is close to perfect. If it is lower, use regular unleaded. The octane of a fuel only increases power if you can copress it enough. You can't run nitro methane like top fuel cars b/c you don't have a 26:1 compression ratio. You only need to replace the cat if it is clogged. Catalysts don't go bad. You're better off just running 87 so you get a complete burn. Let your engine get warm too.
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
06-02-2004, 02:11 PM | #17 | |
fuel with greater octane burns slower ( i think i know what im saying )
some say that the higher the octane the easier u can pass smog. Others say to just run the car for an hour or so on a full tank. I think the purpose of running the car is to make the emissions flow well. After that u can check it urself by checking if the emisions dont sting ur eyes that much, and u can always check if the gas cap is good just in case although i doubt its bad, and then take it to smog check.
1991 240SX KA24DE |
06-02-2004, 04:17 PM | #18 | ||
Banned
Re: Re: Reducing Hydrocarbons (HC)
06-02-2004, 08:51 PM | #19 | |
the engine of my friend's misfires. Also it fail emission cuz by the HC ppm. To fix that, replace spark plugs? IT helps the misfires and might pass emission right??
06-03-2004, 10:33 PM | #20 | ||
lol if emissions dont sting your eyes......i wonder how many kids went and stuck there eyes in front of there muffler pipe to see if it stung or not whahhahahhaahhahaahah. |
06-03-2004, 10:33 PM | #21 | |
Banned
Replacing spark plugs wwill only change something if there's something wrong with the one syou have now.
06-04-2004, 08:14 AM | #22 | |
OK, I know I'm gonna get slapped by logik23 for this one, my cat is clean, but another solution recommended was to advance the timing... when I took the car into do the smog, my timing was at 18BTDC, since the car is supposed to be at 20BTDC, is 18 retarded, or advanced? Do I want to set it back to 20, what do you guys recommend?
06-04-2004, 08:57 AM | #23 | |
Banned
I won't slap no one, but get timing gears, or else ask a shop.
06-04-2004, 11:43 AM | #24 | |
Yes a cat makes that big of a difference. A huge dirrerence. They do wear out. They usually start going downhill after 100k or so. Replace it. It's the best thing you can do assuming your engine is running fine.
Lower octane should help you pass emissions easier. Octane ratings measure resistance to burning. Higher octane is harder to burn and pollutes more. (this is if it's higher than recommended. ie:if your manual sais 87, use 87, if it sais 91, use 91) Lower actane than needed could cause ignition retardation and also cause emissions problems. So unless you're running forced induction or higher compression use what the manual sais. You also definetly want to make sure your ignition system is in good shape. Poor spark (from bad cap, wires, plugs etc...) causes unburnt fuel. Not only will that ruin your emissions in the short run, it will also wreck your cat. Warming the engine is a good idea. Rev it up a little bit before you go in. You want the cat hot to burn up any left over fuel or other emissions. (ok, it doesn't "burn" everything, but it has to be hot to work). Also, metal expands when hot so a warmer engine will help any compression problems you may have. Sorry, I don't know the answer to your timing question. And, remember, emissions are more than just being allowed to drive on the road. I live in MN where we don't have emissions anymore. When we had them we had great air quality. We got rid of them and now were all breathing nasty crap all day. So don't go with quick fixes, respect the environment. |
06-04-2004, 12:07 PM | #25 | |
Can anyone tell me the diameter of a stock cat converter on a 1990 240sx SE?
06-04-2004, 02:34 PM | #26 | |
go measure it...im not sure otherwise. so with the octane stuff, is 87 higher than 91, cuz people always say, use 91 it burns cleaner blah blah blah... cuz by what you were saying, i thought that the higher it was, the worse it burned. im so confuzed now.
RAF Mildenhall, UK 92 Paseo (Died) 90 Corolla (Died) 89 240sx (sold then died) 85 735i (Died) 95 Corolla (Damn Deer) 94 Renault Espace (gave away lol) 94 BMW 316i 97 BMW 528i 97 Blazer trackrunner2004@gmail.com |
06-04-2004, 06:53 PM | #27 | |
When i say higher and lower I mean numerically. As in 91 is a higher octane rating than 87. This means 91 has a higher resistance to burning and there fore needs more compression or forced induction to burn fully. (a good spark helps a lot too) Higher octane fuel is harder to burn. You used to be able to get much higher octane (94, 95 etc...) at the pump. This allowed for higher compression engines and thus more power, but common octane levels were lowered (87 being most common) to reduce emissions. So lower octane is definetly better for the environment, just not as good for building high performance engines. That's why race cars use HIGH octane gas. Clear? I hope so........I'm not always the best at explaining things.
I'll make it simple. The higher the number, the harder to burn, the worse for the environment. |
06-04-2004, 07:12 PM | #28 | |
all clear
06-04-2004, 08:14 PM | #29 | |
about the 20 btdc and it being retarded...it is better if you had it retarded which reduces hcc and nox...advancing will increase them both.
Hiya... Need a FSM? Hit me up I'll send it to ya for FREE! I only have the 91-98 240sx, s13 ca18det, and s14 sr20det FSM Sorry no 89-90 yet.... Mods: Tein Flex with EDFC Hotshot Header R32 GTR Seats Advan SA3 16x7 16x8 Apexi Dual N1 Exhaust Silvia Front End Conversion Digital Climate Control Nismo 2-Way LSD Injen Intake w/ CAI |
06-06-2004, 01:39 PM | #30 | ||
Thread Tools | |
