Go Back   Automotive Forums .com Car Chat > Buick > LeSabre
Old 02-08-2012, 10:34 AM   #16
imidazol97
AF -Advisor
Re: 97 LeSabre wouldn't start during/after blizzard
Originally Posted by scottsdale1955 View Post
However, I'm getting a bad suspicion that the UIM is part of the culprit. When pulling the plugs out, I did notice some coolant around the UIM... so apparently it did start leaking.
I'm not sure that indicative of the UIM leaking. I believe that's just coolant wicking up through the threads of the bolts. I believe they are to have a sealer applied to prevent that.
imidazol97 is offline   Reply With Quote
Old 02-18-2012, 08:45 PM   #17
scottsdale1955
Sorrty for the delay; I ended up just having it towed to a garage. The weather has been so screwy here that it hasn't been in my favor to work on it outdoors. I saw a small pool of coolant around the lower manifold after taking pics. The flash helped to show areas my flashlight missed But anyways, the plenom had a crack in it that was letting coolant seep into the cylinders. (well, number 6 primarily) Only drawback to bringing it in is that he didn't replace the ERP pipe... i just don't want the new one to melt, so I'll do that myself after I pay for the repair & get it back. Thank you for all the help! I'm looking forward to getting my tax return so I can get the garage insulated...finally
scottsdale1955 is offline   Reply With Quote
The Following User Says Thank You to scottsdale1955 For This Useful Post:
HotZ28 (02-18-2012)
'02 Astro, 50K miles on it, wouldn't start and wouldn't be jumped, then later on did start. Battery? Alternator? Fordina M Bodies 9 12-29-2010 05:16 PM
'98 cavy wouldn't start after dying battery NuBlackCavy Cavalier Problem Diagnosis 0 08-27-2007 05:45 PM
95 LeSabre engine stalls 5sec after cold start gerhardm LeSabre 4 11-10-2005 11:33 PM
Buick Lesabre Hard start after sitting Always! bridget36907 LeSabre 1 01-16-2005 11:38 AM
Lesabre Hard start after sitting a while! bridget36907 LeSabre 3 06-03-2004 08:29 AM
Tags
cold , lesabre , start , weather
