Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-01-2004, 09:20 AM   #1
bsmitty
87 dodge ram 250 died on me any help?
I was driving my truck home one day and it all at once quit. It has a 360 motor. I have no spark. I have already tired changing the distributor, coil , electronic ignition box, and the switch. Nothing is helping. Can someone help me out with this?
bsmitty is offline   Reply With Quote
Old 06-01-2004, 09:33 AM   #2
slantsixness
slantsixness's Avatar
Re: 87 dodge ram 250 died on me any help?
Check diagnostic codes :
http://www.allpar.com/fix/80s-codes.html
Check fuel pump relay./ ASD (auto shut down) relay
Check for spark...
Check for fuel if you have spark.
check distributor for no/erratic rotation (broken timing chain)
could be:
Timing chain
Fuel pump (even if it's mechanical, but in '87 should be TBI and SMEC controlled)
fuse links (the little barrels beneath the hood hinge in the wiring harness)
ECM fuse? (In the fuse box under steering column)
MAintenence reminder? (behind the glove box, to the right under the A/C vent (if you have A/C) pull the battery and install new 9v battery and reset by pushing a toothpick in the little hole and push down)
Ignition circuit voltage(s) can be tested (to be sure it works) by checking the RED and PINK wires on the steering column ignition switch connector (left side of steering column, bend clip down to loosen the harness. Both should read 12-13V with ignition ON.
There are some other possibilities, but let me know where you've gotten...
Slantsixness
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
slantsixness is offline   Reply With Quote
Old 06-01-2004, 11:33 AM   #3
bsmitty
Re: Re: 87 dodge ram 250 died on me any help?
I have no spark
I checked the distributor, it is turning
fues look good
Old 06-01-2004, 11:34 AM   #4
bsmitty
All yeah and my timming chain looks good too
Old 06-03-2004, 07:02 AM   #5
slantsixness
Test for voltage at the column, and the ECM by the battery
Red and pink wires with the ignition on.
See if you're losing it through a fuse link... they don't always look bad...
Search this Thread:
