10-27-2004, 12:32 PM | #1 | |
Speed Sensors
Where are the speed sensors located on a 2000 Dodge caravan!!!
10-28-2004, 12:52 AM | #2 | |
Re: Speed Sensors
it located under the air box.. remove you air cleaner 2-10mm bolts on top and 1-10mm on the bottom box. On the transmission you will find 2 beige sensors. You need a 1-inch deep socket and a 1 or 3 inch extension...Is there are reason why you are goind to check/ remove you sensors...
Also the one closest to the engine side is input and the output is the farthest. |
