Go Back   Automotive Forums .com Car Chat > Lincoln > Navigator
Old 04-03-2009, 09:42 AM   #1
coldnsnowsucks
abs
Please help, I have a 2002 navigator and my abs light is on. i have code 1095 which is for a hydrolic pump motor circuit. i went to the lincoln garage and they told me it is prodbably the relay for that... i can not find out where this relay bolts on at. can anyone please help
coldnsnowsucks is offline   Reply With Quote
Old 04-03-2009, 07:21 PM   #2
jahale
Re: abs
there are 3 fuses that you should check 1 is in the battery junction box the other 2 are in the central junction box under the dash. this does not use a stand alone relay, more than likely a problem with the ecu/hcu unit. hope this helps
jahale is offline   Reply With Quote
