Thread Tools Search this Thread
Old 03-21-2015, 12:55 PM   #31
Hemi Killer
Re: 73 Camaro
Originally Posted by Scale-Master View Post
Yeah, I've broken the 700R4 a few times too. Now it has extra clutches, the shifter has a 4th gear lockout for the track and I set the TV cable to shift at a lower RPM on the street. Been working fine for at least 18 years.
Mine is in my 06 GMC 1500. I got tired of it and built my own. Transgo HD2 shift kit, billet output shaft, Sonnax accumulators and Beast sun shell, Delco 5 pinion planets, new pump and a bunch of other stuff. 3000 rpm converter.
Have a 1 year old, so no more mods yet, but the plan is to keep in N/A 5.3 with cam, heads, etc.
I like how you made the block and pan completely different textures, looks really good.
Hemi Killer is offline   Reply With Quote
Old 03-22-2015, 12:38 PM   #32
Scale-Master
Scale-Master's Avatar
Re: 73 Camaro
Despite warnings of fit issues especially since I attached the rear panel to the body, it seems to fit quite well with all the interior parts and glass temporarily installed. The firewall is a little tight to install, but once I modify the kit part to match my car it should provide a bit more wiggle room.
Scale-Master is offline   Reply With Quote
Old 04-17-2015, 12:16 PM   #33
Scale-Master
Re: 73 Camaro
The trans has been painted…
Old 04-17-2015, 12:17 PM   #34
Scale-Master
Re: 73 Camaro
I started making a GM HEI distributor for it and when I mocked it up on the engine block I realized I’d better check for clearance under the hood before getting too far along.
That meant I needed to first address the transmission cross member since on my car the factory one is modified and installed 180 degrees to accommodate the 700R4.
I sawed the cross member out of the subframe and filled the two holes. I drilled and pinned it for a positive fit. I also began filling in the top of the subframe with filler. (The orange one is the way the kit comes.)
After test fitting this subassembly into the body/chassis I can see it does have enough clearance and is similarly tight like the real counterpart.
Old 04-22-2015, 11:04 AM   #35
Scale-Master
Re: 73 Camaro
I decided to work on the front suspension since I was tinkering with the sub-frame. I installed a C4 Corvette fiberglass monoleaf set up on the real car. So to add it to the model I made a brass insert for the cross-member where the spring will be mounted.
The upper control arms and spindles are the factory GM units, but the lower control arms are special made items. I made this pair from sheet styrene.
Old 04-22-2015, 04:34 PM   #36
mrceej
Re: 73 Camaro
Wow lots of detailed progress since I last checked in!
mrceej is offline   Reply With Quote
Old 04-22-2015, 06:13 PM   #37
Scale-Master
Re: 73 Camaro
These will become the front (Koni) shocks.
Before assembling the main suspension parts to the sub-frame I figured I should make the sub-frame connectors. They are built up out of sheet styrene and brass. I also had to open the rear of the front sub-frame rails to accept them, like the real car.
Old 04-22-2015, 06:57 PM   #38
tonioseven's Avatar
Re: 73 Camaro
Beautiful work as always!!!
Old 04-23-2015, 02:36 PM   #39
Scale-Master
Re: 73 Camaro
Thanks Tonio!
Might as well make the traction bars while I’m in the area… I milled the U channel stock from a stick of .125 X .25 inch styrene stock, the bars are sheet styrene. I’ll make and add the hardware later.
Old 04-24-2015, 02:12 PM   #40
Scale-Master
Re: 73 Camaro
I started painting some of the base colors of the chassis. The red oxide is partly visible on the real car where I stripped away the undercoating before installing the engine and trans.
The cross member on my car is bright red; ironically the instructions call out for a non-prototypical yellow for the rear sway bar, and I painted mine yellow back in the 90’s.
The engine was test fitted once more…
The rear suspension ride height is set up.
And the track is set.
Old 04-25-2015, 07:29 PM   #41
Scale-Master
Re: 73 Camaro
I cut the front sway bar off the lower control arm/tie rod/cross-member assembly and reshaped it to fit the new lower A-arms. I started with brass rod for the stabilizer links and will flesh them out with hardware later. I figure the yellow paint fattened up the thickness enough to approximate the 1-1/4 Suspension Techniques bar I put on the real car…
Old 04-28-2015, 12:30 PM   #42
Scale-Master
Re: 73 Camaro
I cleaned up the tie rod assembly that was cut off earlier and added it back to the front sub-frame and installed the steering box.
Old 06-17-2015, 07:51 PM   #43
Scale-Master
Re: 73 Camaro
I installed the fiberglass mono leaf front spring.
Old 06-18-2015, 09:42 AM   #44
hirg
Re: 73 Camaro
10 to 10!
hirg is offline   Reply With Quote
Old 06-18-2015, 01:19 PM   #45
sbvwfanatic
Re: 73 Camaro
Wow. Great job on the chassis.
sbvwfanatic is offline   Reply With Quote
Bookmarks
Search this Thread:
