Go Back   Automotive Forums .com Car Chat > Chevrolet > TrailBlazer | Trailblazer EXT
Old 07-18-2018, 04:29 PM   #1
chiccokaiser1
Ac compressor
Hi. Can anybody guess my a/c compressor oem number? 2002 4.2 6L ltz with rear blower. So I can buy correct part by the time it got noisy... Thanks
chiccokaiser1 is offline   Reply With Quote
Old 07-19-2018, 10:57 AM   #2
chiccokaiser1
Re: Ac compressor
Vin is 1gndt13s022430220
Old 07-19-2018, 03:23 PM   #3
aleekat
Re: Ac compressor
Call the dealer parts guy. They are usually pretty helpful.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Old 07-20-2018, 09:23 AM   #4
Schurkey
Re: Ac compressor
It's a long-distance call from Italy.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Schurkey is offline   Reply With Quote
Old 07-20-2018, 09:01 PM   #5
Tech II
Re: Ac compressor
Old 07-21-2018, 04:56 AM   #6
chiccokaiser1
Re: Ac compressor
I have seen on rock auto but I have also seen there are different types of compressor. I would like to make sure I buy correct part.. by vin maybe..
Old 01-28-2019, 12:34 PM   #7
chiccokaiser1
Re: Ac compressor
Hi. Do you believe it is possible to replace clutch bearing without take off the entire compressor? I would try that before. What do you think? Thanks
Old 01-29-2019, 12:31 AM   #8
brcidd
brcidd's Avatar
Re: Ac compressor
Last 2 or 3 Trailblazers I worked on- for a/c inop- had the air gap too wide- a/c voltage was at clutch on compressor- just could not draw that armature drive plate in against the spinning pulley face. Answer has been simple- remove the drive plate 10mm nut and wiggle loose the plate that is on a splined shaft. then carefully remove any and all shims in behind. Throw the thickest shim over your shoulder and replace clutch drive plate with remaining shims if any. Now air gap is back to speck and compressor will run another 5 yrs.
Can be done while a/c compressor is still on vehicle and charge does not have to be removed.
If this is not your issue- please ignore....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 01-29-2019, 09:59 AM   #9
chiccokaiser1
Re: Ac compressor
Fine.. thanks for your super detailed analysis.. by the way what was the symptom for the defect you found? My compressor is a little little bit noisy when clutch engages. Could your theory fit for me?
Old 01-29-2019, 10:01 PM   #10
brcidd
brcidd's Avatar
Re: Ac compressor
In my scenario, clutch does not engage.......
'99 GMC Yukon
Old 01-30-2019, 06:10 AM   #11
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Re: Ac compressor
It will probably be easier to identify the compressor by its part number instead of the vehicle VIN.
Any reciprocating compressor will emit some noise when operating due to valves. If the noise is impulsive, that could be normal. If the noise is knocking or grinding, that could be a mechanical noise from a bearing or piston. If the A/C system has been serviced, was the oil replaced?
With the engine off, can you grasp the hub of the compressor clutch and turn it by hand? If so, can you feel any grinding from a bearing?
Old 01-31-2019, 11:35 AM   #12
Tech II
Re: Ac compressor
Is the noise there when the compressor is not running, and quiet when it runs?
Old 02-06-2019, 01:09 PM   #13
chiccokaiser1
Re: Ac compressor
Sorry if I answer so late but automotive forums mails ended up in my spam..
By the way:
- noise present when clutch engages
- no service on ac system at all since ten years at least, no leaks, works great
- I can spin pulley freely, no bearing game but a really light hiss
- I can spin compressor by hand, not freely but not stuck, seems correct to me
Looking closer at the compressor, bearing should work when clutch is off so it is not my case.. not lucky.
