| Latest | 0 Rplys |
11-05-2004, 03:15 PM | #1 | |
'01 Galant Audio Wiring Colors=?
trying to locate a diagram of the aidio wiring diagram for the mitsubishi Galant, 2001. Or, are you able to guess what the following wire colors are for?
White with red stripe and white with blue stripe =speaker Gray with red stripe and gray with blue stripe =speaker Yellow with red stripe and yellow with blue stripe =speaker Black with red stripe and black with blue stripe =speaker Here are the problem wires: (1)Yellow with a black stripe and (1) Black with a yellow stripe=? (1)Black with a red stripe=? (1)Red with a black stripe=? (1)Green with a white stripe=? and an all Blue wire=? Thank you very much, if you are unable to offer an educated guess, do you know where else I might look? |
12-20-2004, 05:07 PM | #2 | |
see attached picture of the harness that plugs directly into the harness in the car, as I have labeled the wires on it, but remember what you are looking at is opposite layout of what is in the harness in the car if u hold them next to each other (meaning the order from left to right becomes right to left).
also I did not labeled the wire for the dimmer as I have removed it from the harness, without this wire the dimmer on the dash board will not work, so if you want a dimmer to work you'll have to see which wire is left unused, but also make sure that that wire is not used for power antenna. hope that it helps a bit. P.S. not sure how the pics get attached here, but I guess you'll have to click on GALLERY at the bottom of my reply to get to the picture good luck and hope that it helps a bit. |
